Question about Samsung Digimax S730 Digital Camera
Turn on then three beeps and turns off - Samsung Digimax S730 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 16, 2010
  • SareyM Dec 14, 2010
    You are a star! Thanks for the tip.
  • Andrea Lock
    Andrea Lock Dec 14, 2010
    Thank you so much for coming back to me.
    Kind regards
    Lock123
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
MACHINE WILL NOT INITIALIZE RIGHT OUT OF THE BOX. JUST BEEPS
Make sure the switch is on REG mode. Make sure there are NO batteries in it. Turn power off at wall for a few minutes. Turn on and it should beep three times. Then put the batteries in. If it beeps more than three times, the printer is probably jammed or faulty. Make sure it can turn. Try taking the ink roller out as it sometimes gets sticky and jams the printer.
Mar 23, 2016 | Sharp XE-A101 Cash Register
Macbook Air keeps beeping three short beeps in a loop
I need more info on which model Macbook air you have. You can try to reset the smc and pram https://discussions.apple.com/docs/DOC-3604
but three beeps is often memory related
http://support.apple.com/kb/HT5860?viewlocale=en_US .
Depends on the model you have whether or not the RAM is removable.
Oct 11, 2013 | Apple MacBook Air
Ps3 turns on then turns off and beeps three times
Sounds like a power supply issue. Unless it is showing any other colours after the green light. Red would be ylod which means a phone call to Sony. Try a new power supply and see if that fixes it.
Dec 29, 2012 | Sony Playstation 3 (PS3) Console
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
HAS A BLANK SCREEN WHEN POWERED ON AND NO SOUND
i got this from getupart from this site and he/she said....
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps and damn it works!
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is showing a blank screen when i turn it on wjat should i do
turn it on then hold the power button till it turns off fully then turn it back on but hold the power button till u hear 3 beeps- The turn on beep- a second beep- then a double beep(third beep) go to option three and see if that works
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Vw cabrio key remote programming
First, you will need two keys. Put one key in the ignition and turn the ignition to the "on" position (instrument cluster lights come on). Make sure the hood, trunk lid, and both doors are closed. Take the other key and stick in the driver's door lock. Turn the key counter clockwise and hold it in this position until you hear three beeps. Release key but don't remove it. Press the lock or the unlock button on the remote until you hear a beep. Once you hear the beep from the remote, turn the key in the door counter clockwise again until you hear three more beeps. The three beeps are the signal that you are entering/exiting program mode. The one beep from the remote lets you know that the remote has been programmed.
Dec 12, 2007 | Compaq HP Easy Access P/S2 Carbon/Silver...
Samsung Digimax S730 Digital Camera Logo
449 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
