Question about KitchenAid Washing Machines
I have a Kitchen Aid Superba Sure Care Three Speed Whisper Quiet Large Capacity Heavy Duty Washer. The machine fills with water and then goes through the wash cycle. When the wash cycle is complete it stops there and will not drain the water and go in to the spin cycle.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
onthejob5130
  • 640 Answers
SOURCE: What is the capacity of a my washer.
4.2 thats about 26 pounds
Posted on Jan 04, 2009
walesarumi
  • 6993 Answers
SOURCE: Washer works great, but only
This is a common problem with Whirlpool washer.
Examine the transmission spline for wear. When stripped, this prevents the agitator from properly gripping the transmission shaft. The spline or the agitator itself may need to be replaced.
In other words, the Spline or agitator of the top half of your washer is the cause of the problem. These two parts may need to be replaced.
Good luck.
Posted on Feb 02, 2011
mc1bean
  • 3053 Answers
SOURCE: WASHER GOES THROUGH THE WASH CYCLE THEN STOPS. WONT DRAIN THE WATER AND WONT SPIN
Lid switch needs to be replaced
Posted on Sep 23, 2012
  • 19 Answers
SOURCE: maytag dependable care quiet plus heavy duty 2 speed super capacity washer fills with water but won't agitate spin or drain
I presume that you read your manual on that problem. I have a Maytag. So far mine is not quiet so I cannot help you with that area but if your washing machine is not spinning or agitating if you are still under warranty FIRST CALL the manufacturer. That way you will not void your warranty. If it isn't under warranty, CALL them anyway. The help line knows a lot about those problems. Now on my old one - not one of the new ones - I had a warranty on appliances. Washer was included. They told me that the belt was not turning something in the motor. It was either worn or broken. Either way don't you try to fix it. Unless you are a machine repair person - do not try to get to it. You cannot imagine how many little pieces were included in that motor. Even a motor scheme sheet for your machine will not be worth your time. They did fix mine. I just gave you the speech the repair person gave me. The house call was not very much. That was back some years so -25 - 50 dollars for another 10 years of usage was good. I read the instructions to everything. That is just my inquisitive nature. However, that may be a headache to you. So get your manual out and go to the troubleshooting section. If you don't see an answer, look on your washing machine and get the model AND serial number. MAYTAG used to have that information on the lid or door somewhere. It is very hard to use even with a magnifying glass. Choose a time you are in a good mood. If you cannot find it, call the store where you purchased it. They can give you all of that information and where to call. Or they can tell you your warranty information and some of the reasons it might be happening. Last, go ahead and dip that water out of the machine tub. That will be way more water than you anticipated. If you haven't, remember you are working with water and electricity. Put on your boots - just because it is a messy job. Now, before you start UNPLUG EVERYTHING. Last, if you have an older model, it might take a while to get parts. Be prepared to do a little light sink sudsing and wearing clothing more than once (smiling.) More than likely this is a Maytag repair problem. If you cannot find your warranty information, when you call the retailer, they have it. If you bought it at Home Depot or Lowes they will have ALL of your information. Isn't technology wonderful??
Posted on Jan 23, 2015
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
Hello, I love my Ktchen Aid washer and have had it for over 17 years! It is a 3 speed, quiet scrub, extra capacity/heavy duty. The water fills the tub, but does not shut off and over runs onto the...
All you need to do, is see if you can find a Pressure Switch available at a Spares Depot. This is the problem with your Washing Machine. I do not know if you will still be able to get one though. The pressure switch notifies the Timer/Module when there is sufficient water in the Tub to commence washing.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | KitchenAid Washing Machines
Using enough water or not enough?
No affiance but dident your Ma Ma show you how to do laundry. Ask your neighbor to show you, and make a new friend.
Apr 20, 2009 | KitchenAid K5SS Heavy Duty Commercial...
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Washing Machines Logo
415 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
