Question about Mastercool Portable Air Conditioner
Need replacement pads MMB12B were do i get them an what is the price
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Price for front and back rotors and pads for my GMC Envoy. Can I do by myself ? 4 wheel drive SLE model. are these Canadian prices
You can buy and install these yourself, very easy job. Any automotive retailer will have all in stock.
Depending on the grades you buy, pricing can vary greatly.
OEM replacements for rotors are about $39 a piece. (Can probably find cheaper online)
OEM replacements for the pads are about $20 an axle.
Pricing can go up a lot if you decide to get drilled and slotted rotors, or high end pads.
Pricing is in US dollars.
Apr 12, 2011 | 2003 GMC Envoy
When i brake i hear a scratching sound coming from the front tires
This is probably the begginning of needing new brake pads. Brake pads have wear indicators that will scratch and/or squeal when the pads are starting to run out. Have them checked soon because if they continue to scratch badly you will need to replace the rotors too and that raises the price alot.
Mar 01, 2011 | 2008 Scion Tc
Some of the touch pad numbers on my microwave are not working
That is usually a faulty touch pad.
Contact an appliance engineer to get a price for replacement and ebay for the spares to see if it is a fair price.
Hope that helps.
Feb 25, 2011 | LG LMV1680 Microwave Oven
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
How often do brake rotors need to be replaced? and what is a decent price for rotors, pads? subaru legacy wagon, 2008
They will need replacing when they are at the minimum thickness, which is stamped on the rotor in most cases. If they are rusted, they will need replacement anyhow. you may just call a few repair shops and ask for a quote on pads and rotors. Asking a quote for brakes is hard, because they dont have the car to inspect it, and its hard because nobody quotes the same parts, apples to apples. the cheapest is not the best deal, you get what you pay for. Get good quality brakes, your life depends on it. if it was me I would use dealer parts.
Oct 15, 2009 | 2008 Subaru Legacy
The brakes on my 2001 nissan frontier are slow, whats the price to replace them?
This really depends on whether you need to replace the pads or the pads and the rotors. Assuming that you need to only replace the brake pads on the front of the vehicle you are looking to pay somewhere between $80-$150 to get it taken care of. A great site that you can visit to find out how much common car repairs should cost is http://repairpal.com/. Let me know if you have any further questions. Thanks for rating my response and for using FixYa!
Jul 29, 2009 | 2001 Nissan Frontier Crew Cab
Do i need to change the brake pads and discs???
No you don't, you can have them turn the brake disk/rotor . Turning the brake disk/rotor is when you have the surface of the disk resurfaced by having a brake lath cut the high spots down. The disk are cheap enough now that most will just replace the disk/rotor the same time they replace the brake pads. You can pick up performance drilled or slotted brake disk/rotor for almost the same price as the OEM disk/rotor. Good luck and hope this helps, you can pick up the slotted brake disk/rotor at Auto Zone for a reasonable price and they will have the step by step instruction replacing the disk and if you like to just have the disk/rotor turned, they can do they there too.
Jun 07, 2009 | 2002 Volvo S40
Mastercool  Portable Air Conditioner Logo
57 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
