Question about Samsung RS2630SH Side by Side Refrigerator
My samsung side by side fridge freezer has become spasmodically very noisy at the back of the unit. when you open the door the noise comes to a shuddering stop - advice please
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
HELLO , you probaly want to have a look at this video ? ..
youtube user samsungfridgefreezer
video
Posted on Sep 18, 2010
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Refridgerator make a noise every 3 minutes
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Making noise and not cooling properly , when you open the door the noise comes to a stop like the fan slowing down
Your unit isn't defrosting. Your fan blade is hitting the frost that is built up in the back of your unit. All Samsung units are made when you open the door that the fan stops. You can check this but finding your door switch and see if the sound still continues. But you will need service and a part to fix this unit. Where are you located? We are the master tech company for Samsung in the Charlotte, NC area.
Aug 12, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung RS2630SH Side by Side Refrigerator Logo
158 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
