Question about LG Studioworks 552V 15" CRT Monitor
Kindly i need driver for LG Monitor Studioworks model 552v
    Problem Solver:
  • 12 Answers
How to change my display setting when my monitor sudden stops working at 1076x768 high resolution
uhh it obiously cant take that resolution maby it can try install a new driver if that does work sorry it can take that high of a resolution
Jan 12, 2011 | LG Studioworks 552V 15" CRT Monitor
LG Studioworks 552V monitor incompatibility problem.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 06, 2010 | Computers & Internet
I have lg studioworks 552v monitor connected to a windows 98 computer . the screen had some problem before now rectified but i had 256 colour running now after repair there is only 16 colour . how to get...
In Win98, you will get only 16 colors if you don't install the VGA driver. It is not a problem with your Monitor. Install the VGA driver. If you can't find the driver (we may be able to help to find it), try replacing the VGA.
Apr 19, 2009 | LG Studioworks 552V 15" CRT Monitor
Cut off screen
Replace 101 and 104 pf on Main chasis of your monitor :
Darshan
Dec 26, 2008 | LG Studioworks 552V 15" CRT Monitor
LG Studioworks 552V hout burns off
1. cheak the G2 , G4 wires. ( properly fixed it )
2. Near to LOT one flyback capacitor 1600 / 2KV problem.
3. damper diode BYW 96
4. LOT Problem.
Oct 24, 2008 | LG Studioworks 552V 15" CRT Monitor
I have lg monitor thet's problom withe syenc both side
First change external setting thr menu buttons viz..Trapozodical setting etc... If problem not solved Replace Memory Ic -- will get good result
Darshan
Aug 12, 2008 | LG Studioworks 552V 15" CRT Monitor
It is standy by problom.Find the problom instandy by section
Aug 04, 2008 | LG Studioworks 552V 15" CRT Monitor
LG Studioworks 552V 15" CRT Monitor Logo
127 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
