LG plasma tv- 50pc56- zd. suddenly turned off. when tried turn on from remote c. red light from standby transferring into green and flashing few times, after that back to red and nothing. dont want to turn on. i heard with this few clicks inside. ???
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
  • 135 Answers
SOURCE: Lg 42pc1da plasma tv wont turn on
will be a fault with either power or y-sus x-sus board is the tv still under warrenty if so request repair
Posted on Jan 18, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
37LC2D LG PLASMA TV Solid red light is on no sound picture
The unit is stuck in standby. Have you tried turning it on manually on the set or changing the batteries in the remote. Does the light flash when you try to turn it on?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG 37LC2D Television
My LG 50pc56 won't turn on, when I press the standby button either on the remote or on the t.v the standby light flashes green 5 times and then turns green again. I have already tried changing the mai
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 26, 2014 | Televison & Video
TV will not switch on using the remote or manually on TV
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | LG 50PX1D 50 in. Plasma Television
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
May 27, 2010 | Televison & Video
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
