Question about Vacuums
The problem is that the cleaner is heavy to use and does not pull itself forward as it should. It has been back to the supplier 3 times but they have not fixed the problem. The LED's on the front flicker and I think it may be a problem with the sensor. If you have any info. on how the sensor works and where it is located it would be useful as well as any other suggestions to fix the problem please.
    Problem Solver:
  • 6 Answers
If it heavy then do some muscle work and body building
Posted on Sep 16, 2010
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do i disassemble my hoover f7220
Hi there! The tanks, brushes, nozzle and handle can be removed from the cleaner by following these quick steps below.
1. To remove the clean water tank simply grasp the handle and push down on handle to unlock it, then pull the tank out by the handle.
2. To remove the dirty water tank, slide the latches open located on the sides of the cleaner that hold the tank to the base of the cleaner. Grasp the handle and pull up and off.
3. For brush removal, with the handle in the upright position, tilt cleaner back until handle rests on floor. Grab brush assembly and pull firmly.
4. To remove the nozzle, with handle in upright position, tilt cleaner back until handle rests on floor. Pull tab at rear edge of nozzle and pull forward to remove nozzle.
5. For handle removal simply remove the handle screw and lift up on handle.
Disassembly beyond this point is not recommended. Hope this helps!
Jun 05, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
How can i get my upright kenmore vacuum cleaner to move to the vacuum position?
Don't know your brand vacuum but if I understand you correctly the solution should be pretty straight forward unless the lowering lever is broken somehow. Usually there is a foot lever on the left, or sometimes the right, toward the rear part of the base to push with your foot. Step on it while at the same time push it slightly forward first - just a quick 1" forward motion, then pull it toward you. That SHOULD disengage the handle to be able to vacuum freely.
May 02, 2014 | Kenmore Vacuums
Original upright dyson - cleaner head stiff/sticky and won't stay on floor
Hi Kirsty,
I'm sorry to hear you're having difficulty with your DC07.
If the cleaner head doesn't seem to be pivoting freely to maintain contact with the floor, we'd appreciate the opportunity to provide further assistance. If you give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), one of our advisors will be happy to run through some troubleshooting checks over the phone with you to determine the cause of the issue. They may even be able to talk you through through fixing the machine.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 29, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Bissell 1690 carpet cleaner and it is leaking water very quickly out the back. How can I fix this problem?
I had the same problem with my bissell proheat carpet cleaner. My cleaner would leak water out the back when i turned it on. I opened up the cleaner and found there was a broken tee connector. The tee connector was a small black plastic three way connector shaped like a letter "T" with three plastic hoses plugged in to each end. One hose had broken off from the tee, the tee connector itself had snapped. Bissell has a couple hoses that run up through the upright porsion of the cleaner, i believe if that hose gets pulled too hard by over extending the cleaner upright portion it can snap the tee connector.
I purchased a vacuum line tee connector at the local auto parts store for a buck and replaced it. The vacuum line connectors are for rubber lines on a vehicle related to the engine, but they work fine for the Bissell. The size i purchased was 3/16"x3/16"x3/16". The cleaner works great now!!!
Here is how i took it apart:
I removed the water reservour, the soap dispenser, and the cap for the air flow indicator (red spinny thingy).
I removed the two screws in the very back, the two in the middle on each side of the water resevour and the two in the front. I carefully lifted the top of the cleaner off.
Inside you have to watch for a black plunger piece that might fall out, it belongs to your (heavy traffic/light traffic/water only) turn knob. If the plunger falls out reinsert it back into the underside of the cleaner lid right next to the knob, you will see how it fits in there...hopefully. Inside the bottom portion of the cleaner you will see a few hoses. Check them all and make sure none of them are disconnected or broken off from the tee connector. I would almost bet that this is what your problem is if the machine is leaking. replace the valve, reconnect hoses and carefully reassemble the cleaner.
Hope this helps...
Jun 25, 2010 | Vacuums
It won't move forward. it turns on but drags when going forward will go backward smoothly.
On the front of Carpet claner is the clear part that pulls the water back up. It may have come apart. this will cause it to catch, unplug the cleaner, remove all the cleaners and water container, then , lift up and look at this part, If it has a large gap it has come apart.
Mar 24, 2010 | Bissell 1699 ProHeat Clear View Upright...
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Using too much solution AND leaving dirty streaks in my carpet
The reason for it to use soloution is it may be set on heavy traffic. To fix this turn your knob labeled heavy,normal& light traffic and water rinse to either normal or light traffic. To fix the streaks when you pull the machine backward pull it super slow (you may have to do this a few times) if this dont work take it back
Jul 31, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
DC07 Very difficult to push forward.
on the front of the base there are 3 very small rollers made out of rubber, these are either just dry and won't turn or worn and or damaged,
that is your problem / honest its that simple
Oct 13, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
