Question about Grohe Plumbing
I just replaced the cartridge in my KWC faucet and now it's very hard to raise and lower the on off handle. Any advice?
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
It is possible that you installed a bad valve cartridge, it would not be the first one. It is also possible to over tighten the cartridge retaining nut, rare, but it can happen. In either situation you need to call KWC and ask them to send you a new cartridge asap. They are usually very easy to work with. If you need further assistance please let us know.
Posted on Sep 17, 2010
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
Kwc kitchen faucet
Usually you need to use a hex key to unscrew.
Could you take a photo of the faucet and show us?
Feb 03, 2014 | Plumbing
Kwc faucet washers
lowes home improvment
Dec 11, 2017 | Plumbing
Remove flow restrictor on KWC Faucet
We have a KWC 10.501.012.000 - Systema kitchen faucet and after installation the water pressure was much lower, even after adjusting the faucet's limiter screw to "minimum". We ultimately decided that the reduced flow was unusable and called back the plumber service. They sent out a different guy this time and he knew where to find and how to remove another of the faucet's built-in limiters (it has three, apparently).
I saved the removed water limiter parts. I hope this picture of them can you or anyone else with this same problem remove the limiter and get strong flowing water again...
Jul 02, 2012 | Dmm Plumbing
I have a KWC K24.41.61.000C06 and I live in a drought region. How can I limit the flow on the main faucet?
This faucet is designed to run full open and has no adjustments for lowering the flow. I would put something around the handle to keep the lever from opening completely maybe some pipe insulation or tape. Now you could get into the hose connection where the filter screen is and make a small washer type deal with a small hole in it to restrict the flow.
Feb 09, 2011 | Dmm KWC K.24.41.60.000C28 Gastro Kitchen...
KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
Nov 09, 2010 | Danze D403412 Melrose Single Handle...
I need to replace the #14699 retainer pivot nut on my single lever faucet and need to know how to do so.
pop the cap on top the handle,remove screw,work handle off and unscrew retainer nut. a tip,raise the center of cartridge up when you reassemble,so it work's good .
Feb 22, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
Plumbing Logo
604 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
