I have a 16 gb memory stick and had this in the USB port - it was working. However, the stick was bent while in the port - now it won't read at all. Have a lost all of my data which is very important to me? Please advise. Sheila Kerr
  • 95 Answers
You can contact 1.866.857.5950- eProvided recovers all data: USB flash drives, thumb drives, pen drives, memory sticks & any flash storage.
Posted on Sep 16, 2010
    President:
  • 2,571 Answers
You must have broken the solder contacts on the usb connection.
Your only hope is to open the pendrive up and see if you can re solder the contacts.
Other than this you would have to take it to a data recovery company, this costs lots of money
Computer does not reconize mermory stick
Either the port on the computer is bad or the memory stick is bad.
If you are using a usb port to plug in the memory stick, try another usb port.
Try plugging the memory stick into another computer to see if it works or if it is bad.
Jun 02, 2012 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I have bought a Kingston 16 GB USB Pen Drive, But when I Plugged in the Pen Drive it doesn't worked at all. Please Help me...
Seems like there is either a problem with the USB stick, or with your USB port. Do other USB devices work properly? If so, you might want to return that USB stick now it's still under warranty.
Mar 13, 2011 | Computers & Internet
I have a new 500GB Iomega external harddrive. It is now loaded to near capacity with films etc. When I plug it into my USB port on my Sony TV it does not seem to be recognized. When I plug it into my...
1. The TV and drive may not be compatible with each other. 2. The formatting of the drive could be the problem. The USB memory stick would be formatted as FAT32, but the Iomega drive would have been formatted as NTFS. Maybe the TV can only read drives formatted as FAT32 and not NTFS.
Jun 28, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
Laptop will not read some USB Memory Sticks
Is it the older one that doesnt read the thumb drives? If so I actually had the same issue with my laptop and the fix was really easy. First do you have more than 1 usb port on the laptop or multiple usb ports? Have you verified that its all the usb ports on the computer or just one in particular? I found that a build up of dust can immensely affect the way a usb port will work with certain devices. Make sure you dont need to do a quick cleaning. If all is clean then it may be neccesary to go to the website support of each thumbdrive and get drivers for them. It should tell you exactly how to load the drivers to the usb thumb drives.
Mar 11, 2010 | Computers & Internet
I lost all datas from my memory stick
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 27, 2009 | Computers & Internet
Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 05, 2009 | Electronics - Others
Unable to read data on my cruzer 16 gb usb
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect pen drive to computer then check if still face problem try all usb port of computer.
also check your usb port of computer are working fine.
Thanks for using fixya.
Please rate solution if it helps you
Jul 23, 2009 | SanDisk Electronics - Others
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
I have a compaq presario sr1230nx and when i go to put in a ad card the light next to the slot blinks green and then the card cant be read. then the explorer crashes for about 20 seconds and then i tried...
The memory card reader on your computer may not be able to read memory cards over certain capacities (4 GB).
To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Purchase a USB memory card reading device that plugs into any open USB port. Make sure the USB device is capable of reading SDHC. These devices are fairly inexpensive and can be used in any computer that has a USB port.
If the card reader stops working after using Safely Remove Hardware, reset the cable connections and memory card firmware.
Memory card appears in My Computer but errors occur when writing or reading
If you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
  1. Try a different memory card of the same type in the same slot. If the different memory card works, the card reader is good and the original memory card should be replaced.
  2. Some cards have a read/write security switch on the card. Make sure that switch is set to Write Enabled before attempting to write data to it.
  3. Make sure that the amount of data you attempted to store has not exceeded the capacity of the card.
  4. Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
  5. Make sure the memory card is one of the supported types: CompactFlash (1, 2, and Microdrive), Memory Stick, MultiMedia, Secure Digital, or SmartMedia memory cards.
  6. Make sure the memory card is fully inserted into the slot.
    Remove the memory card when the light is not flashing and shine a light into the empty slot. Are any small pins inside bent? Replace the memory card reader or have the computer serviced if a pin is touching another pin. Straighten slightly bent pins while the computer is off using the tip of a mechanical pencil.
  7. If errors persist replace the memory card.
Dec 20, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
PSP
as long as you have connected the usb lead and tried in different ports, make sure you are selecting USB Connection in the settings menu on the psp, it should then connect, but some older pc's may not have enough voltage sent to the usb ports to read the psp, if this is so you will need to buy a powered usb hub.
Aug 07, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
