Question about Whirlpool Refrigerators
The ice cubes and water from the door dispenser has a strong taste of Chlorine or some chemical. I have emptied out all cubes and refreshed the water to no avail. I have no problem with our tap water.
  • 1 more comment
  • Joe Richardson
    Joe Richardson Sep 16, 2010
    Does it have a filter or purifying system that might need to be changed?
  • fclare Sep 16, 2010
    I do not use the filter. It is too expensive and doesn't last but less than six months. It was removed and instructions followed in use after removal.
    Frances Clare
    I have received an incoherent answer to my problem Please cancel the charge.
    I have reported it to the credit card company,.
    Frances Clare
    Genius:
  • 1,416 Answers
Then it means that you will have to make a change of the ice cubes it is the course of the water pollution it ha been con-terminated .
Please carefully answer/think on this question form how long you have been making using of the ice cubes?!
when last did you make use of the cubes before you this note ?! And also were did you place the cudes after use before return it back to the refrigerator .
if all the above question can be look in to then the problem is solve or you get a replacement of a new cubes .
thank you and thanks for using fixya.
Posted on Sep 16, 2010
  • Oloyede Monsuru Sep 16, 2010
    hello,
    what this the respond to the solution giving to you ?
    thank once againg.
Ice cubes in ice tray and food smell and taste bad ammonia. I don't have a ice dispenser
Test the water for contaminants. If you're on a well, you need to filter for ammonia and other chemicals in the water.
Feb 17, 2016 | Refrigerators
Why would ice from the front door have an off taste but the ice in tray in the bottom freezer tastes fine?
I don't see from the literature that this model dispense ICE from the "front door." The dispenser on the left door seems only to dispense water. In your configuration the water comes through a completely closed system until it reaches your glass and should therefore not have an order or taste different from that of your cubes in the bottom Freezer.
Nov 25, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Ice smells and taste like chlorine but tap water does not?
Freezing a liquid is kind of a purification process. For example, an iceburg is pure water even though it is frozen from salt water.
The same thing is happening with your ice. Pure water freezes first and leaves behind the ****. The **** and last bits of ice freeze at the bottom of your ice cube tray. You taste the concentrated **** (including chlrorine) on the bottom of the tray. Some regions, the water is from rivers instead of deep wells. The taste there can get real funky or real strong chlorine.
Sep 09, 2011 | Whirlpool Refrigerators
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Ice maker not pushing out cubed ice makes funny sound also has a chlorine taste even after changing the water filter
The ice cubes may have melted somewhat and are sticking to the bottom of the ice bin.
Take the ice bin out and dump the ice. Wash and DRY the bin. Put it back in and wait for more ice to make,then try your dispenser.
Let us know the outcome.
Dec 01, 2009 | GE Refrigerators
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
The water and ice both have a strong metal/mineral taste to them
Remove filter and use dispenser a lot. Chlorine in water may help clean out system that filter is now removing. Not much else you can do other than replace all the water lines and tank. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
