Question about Pioneer DEH-P6800MP CD Player
Will not turn on no longer, and the grill at first would not open
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
You may have a bad flexible cable that runs from the face to the main motherboard.
Posted on Sep 16, 2010
TV keep turning off and my red lamp light comes on
Red Lamp no longer illuminates and has
reached the end of the lamp life.
Replace the lamp. The TV will not operate when the lamp no
longer illuminates.
or you made need service for the tv..
Jul 05, 2014 | Mitsubishi WD-60735 Projection Television
Grill will only heat up to about 400
Generally, there are 2 things that can cause the problem.
1. The grill thermometer is no longer accurate. To test this, purchase an regular Oven Thermometer for about $6.00, that would normally set on the oven shelf. In this case, it's going to set on the grill grates, when you preheat the grill with the lid/hood closed. Allow it to preheat on High for 15 - 20 minutes. Look at the grill thermometer and then compare it to the oven thermometer. I'll bet, the oven thermometer will be significantly higher, if the grill thermometer is faulty.
2. If you recently turned the gas tank's valve OFF and then turned it back ON later. the grill's gas regulator is partially closed. And the burner flames are not as high as they should be. To solve this problem do the following.
A. Turn the tank valve OFF and disconnect the hose from the tank.
B. Wait 5 minutes and reconnect the hose to the tank.
C. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the vale is fully open, light the burner farthest from the tank first and turn it to HIGH. Does the flame height look correct? If so, light the remaining burners the same way. Now, do all the flame heights look correct for being on HIGH. If so, you solved the problem.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can pick one up from any home center or hardware store that sells grills and accessories for about $30.00. Be sure to take your old one with you for comparison purposes.
I hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 30, 2011 | Weber Genesis Silver A Grill
Gas very slow to come after valve opened - grill connected to natural gas. After waiting up to 1 hour gas eventually comes and the grill will light. Wait time becomes increasingly longer with each use
Unhook the regulator, and open valve momentarily to see if gas is present under any pressure.
DON'T BE SMOKING. If gas hisses out, Replace the regulator with a new one.
Regulator uses springs and diaphrams. Either the spring is weak or the rubber diaphram is stiff or (oil contaminated) swollen and sticky. DON'T try to repair it. Not worth the risk!
Either way, the only thing between the gas supply and the grill is the regulator. Have it replaced.
DO NOT OPERATE WITHOUT A REGULATOR
Jan 10, 2011 | Grilling
I own a brinkmann 810-3825-S and we are trying to smoke pork ribs. So is the lid supposed to be open or closed? And what causes it to be so smokey?
You will want the lid closed, the longer you can hold the heat/smoke in the better the flavor. What makes it smokey is wet wood chips on your coals, a smoker box works great for that but I think this model has it built in. You can get different wood types of wood chips at places where you can buy grills in the same department. You can usually get hickory, oak, cherry and such. Hope the ribs turn out good! :)
Sep 04, 2010 | Brinkmann Smoke 'n Pit Professional...
Replace headlight on 1985 Nissan truck.
I no longer need assistance. I all ready new about the plastic screws, and I managed to unlatch the one latch which was giving me a problem. The other latch easily opened. Thank you!
Jan 05, 2010 | 1985 Nissan Pickup
New grill doesn't light when turned on....
I just had this problem on my 2 year old stainless steel "Charbroil" propane grill. After I checked to make sure the battery is not dead or corroded and the wires were not heat damaged or chaffed. I bought a replacement igniter kit for $9 at the big box hardware store. In the middle of pulling the unit out, I tried to start it again and it worked, after I gave the little black igniter box a gentle tap. You'd be surprised that it works on a lot of electronics from cars, appliances to yes...airplanes! Good Luck!
Jul 17, 2009 | Computers & Internet
The knobs no longer control the fuel flow. What
May be air locked. Try turning off all the knobs. Turn on the gas, wait 10 minutes, turn on the lighter knob again and try to light it.
Jul 01, 2009 | Barbeques Galore Turbo STS 4-Burner...
Grill no longer producing good heat
read manual...possibly triggered propane safety bypass. Close tank, Turn OFF all burners, disconnect tank. Open one burner for 1 minute and turn off again. Reconnect tank. NOW OPEN tank slowly, all the way. Turn on first burner and ignite with starter or light through port hole manually. Hopefully works better.
Mar 25, 2009 | Weber Genesis E-310 Gas Grill
Top knob no longer turns
The valve behind knob has probably gone bad and needs replaced(bad bushing from factory maybe). Check to see if your still under manufacturers 1 year warranty. Or order a new one off manf. website or ebay with model #. Good Luck, hope this helps.
Mar 21, 2009 | Weber Genesis Silver B Grill
Grill Blew up
Yes...........I just had my grill go up in flames as you discribed. The gas hose fitting is a crimpedconnection that connects the hose to a small male fitting. This is not properly enginered ... there should have been a brass conection there. JT
Aug 26, 2006 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Pioneer DEH-P6800MP CD Player Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
