My carrier air conditioner is not working. We have two exterior units. One for upstairs (smaller) and one for the downstairs(larger unit). That being said we have two seperate thermostats inside our home. The upstairs unit is working fine. The downstairs thermostat shows on Auto that the unit should be kicking on based on the temp. However, the outdoor unit for downstairs is not working. So far I have checked the downstairs vents and they are blowing air although not very cool. I also turned the switches for both units on and off in the breaker box. Upstairs unit cut on and off fine- the larger outdoor downstairs unit did nothing. Where should I look now? Thanks, Mother of 6
  • henderson768 Sep 16, 2010
    Thanks- would you be able to give me some step by step directions on how to check these possible problems you listed.
    mother of 6
  • henderson768 Sep 17, 2010
    Sorry it took so long to respond. The fan motor is definately hot. Also the breaker is off but i can still hear a humming sound coming from the compressor area of the heat pump. Didn't have a voltage meter yesterday so I didn't want to go any further with the fear that the capacitor might still be holding some juice(shock) even with the breaker off. My brother is bringing a voltage meter over today- I really think it could be the fan motor.
  • 43,501 Answers
The problem is in the outdoor unit...
The compressor could be locked up, the condenser fan could be bad... or from what you are saying the contactor for the outdoor unit is either not pulling in or is bad...that also can be a result of a high or low pressure switch tripping...
So as you can see there are many possibilities...but all are related to that outdoor unit...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 16, 2010
  • 1 more comment
  • D. Floyd Kolb
    D. Floyd Kolb Sep 16, 2010
    With out an electric meter it is hard... do you have acces too and know how to use one???
    Check that you have electric to the unit...also check for 24v single coming to the unit to tell it to turn on...
    Is the compressor hot?
    Is the fan motor hot?
    This will get you started troubleshooting this..
    heatman101
    after checking voltage and confirming electric to unit- we then disconnected the compressor so as just to have power going to the fan- it became extremely hot very quickly- concluding that the fan motor is bad. Thanks for your help. One quick question- capictor is fine now but is it necessary for it to be replaced along with fan motor to prevent future quick burn out of new motor? Thanks again
  • D. Floyd Kolb
    D. Floyd Kolb Sep 17, 2010
    Yes, the humming is the contactor pulling in, so the indoor unit is trying to make the unit run...
    if the fan motor is hot and it is not running, that is your trouble....you may have to reset the high limit control once you replace the fan to get the compressor to come on then...
    Let me know if you need help with that...
    but for now it looks like you need a fan motor...
    check out www.grainger.com for a motor...
    heatman101
Unit for downstairs is running fine, but upstairs unit doesn't want to kick on, but outside unit is running (fairly hot though). Tried to re-set, but "cool" just sits there and flashes on the...
Are you saying you have two HVAC systems or one? If you have two indoor units, you must have two outdoor units. Which outdoor unit is running. You said it is running hot. Assume the fan in running to cool the condenser. If so it should be about 20 degrees warmer than outdoor air. If not maybe you have a dirty condenser coil. Need more information.
Aug 26, 2011 | Carrier 38CKC036 Air Conditioner
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Mr Slim Model PEH3VK no air in one zone.
The Zone controller needed replacing so I rang for a Serviceman
Jul 06, 2009 | Mitsubishi Heating & Cooling
Compressor fan moter not working
It is likely the capacitor for the fan motor. Unless you are comfortable working with 240v this is an issue for a qualified service tech. If you are comfortable with it, replacing the capacitor is fairly simple, you can probably obtain one from most electrical supply houses. It would be the smaller of the two capacitors contained within the exterior unit, the larger one is for the compressor motor.
Jul 04, 2009 | Carrier 36KCARMS Air Conditioner
AC unit seems to be working normally but not cooling house
If you are referring to the secondary pan there could be a problem with your drain line.i would find the drain at the exterior of your home and **** it out with a wet vac..most A.H.Us have float switches or moisture sensors.They will shut down the unit if the drain clogs.
Jun 21, 2009 | Weather King 10AJA3601AH Air Conditioner
Carrier thermostat reading stuck on 50 but doesn't work
If it is Carrier tstat. Some have resets other dont. Kill power to insid unit. WAit five minutes turn back on. If it has batteries take them out. But the storm may have damaged the tstat. I had a thunderstorm damage 11 tstats in one building. You can buy a tsta at Home depot that will work and they are easy to wire. Just make sure you get the coorect tstat. If the unit is straight cool electric thats the easy one. A heat pump you need a Tsta with two stage heat one stage cool. You can pick one up for about 25 to 30 dollars. Please call back for more help be glad to assist.Rusty
Jun 13, 2009 | Heating & Cooling
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Not enough return air to heating unit
Right now you are at bare minimun for what your unit requires. If you are not having any problems with the unit or have not had any I would not worry about it. You need to check and make sure that your duct size on the unit is not smaller than 14" in diameter. If it is 14" or bigger you are fine.
Dec 03, 2008 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
