Question about Reizen Lands Phones
I NEED TO KNOW HOW TO ADD A THIRD NUMBER TO MY MEMORY. MODEL JT-P550
How do I set speed dial for J WIN JT-P590?
One-Touch Memory
1. In the on-hook or off-hook state, press [MENU] button until the LCD
displays "STORE NUMBER."
2. Press [OK/DIAL] button, then enter the wanted number by using keypad.
3. Press [OK/DIAL] to confirm.
4. Choose the desired location M1 or M2.
5. Press [OK/DIAL] to confirm and the LCD will display "SAVE."
To dial from one-touch memory keys, lift handset or press the speaker and press the
key (M1/M2) and the number in the memory will be dialed out automatically.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Jwin JTP590 Corded Phone
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver"
6.open the software "dnw5.0e"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
Oct 03, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Enjoy.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
Mio p550 USB devise not recognized.
Try a other usb cable had same problem new cable fixed it of other device
Nov 09, 2007 | Mitac Mio P550 GPS Receiver
Unable to see contact directory
open your contacts folder, then go to options at the leftside button of your k pad, scroll and hit copy, then choose from memory card, hope could help.
Jul 31, 2007 | Nokia 3230 Cellular Phone
Lands Phones Logo
16 people viewed this question
Top Reizen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Reizen Lands Phone Expert? Answer questions, earn points and help others
