Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
We are seeing water/steam in the glass so it appears there is a small leak in the front glass panel? Is this a health concern?
Steam between glass doors of microwave
Posted on Dec 01, 2010
Are microwave ovens dangerous to our health
It depends on microwave, and condition, as some can leak so never stand directly in front while on is best safety advice. After all these years I have yet to see conclusive evidence of being dangerous to our health, but remember, only use microwave safe glass containers, not plastic in any microwave to avoid what is known to be a dangerous BPA vapor some plastics emit which penetrate foods, www.FREE-PPV.com
Mar 15, 2015 | Microwave Ovens
My 7qt slow cooker glass cover doesn't have a small hole for the steam to escape, so while it's cooking it is continually lifting the cover spitting out water and dripping over the whole counter, is that...
The slow cooker works by heating the food up to around 85 degrees Celcius and should not boil. If you have it hot enough to boil place a tooth pick under the glass edge. That will let the steam out.
Jan 13, 2011 | Microwave Ovens
Condensation in door glass of GE XL1800 microwave
Your ventilation seals may be aging, but they have nothing to do with microwave energy leakage, (And microwave energy is not ionizing radiation anyway, so it does not cause cellular mutation or cancer)
You should check your grease filters (if you are venting to the outside) or your charcoal filter (if recirculating).
If you are venting outside, check your outside vent flap for proper operation, and check your outlet and ductwork for a bird's nest or mouse nest, etc.
If you have other questions, feel free to contact me directly, because FixYa doesn't always notify us when there are follow-ups.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 09, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Damaged door on microwave
Buy a detector to test your microwave to be sure it is not leaking radiation. The detectors range in price from ten dollars to about thirty five dollars and can be purchased in most hardware stores. If you discover that the microwave is leaking radiation, never try to repair this appliance yourself. Take the microwave to a professional for repair. All things considered though, the microwave oven is fairly inexpensive these days it may be a better idea to just purchase a new one.
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Rust forming between the glass panels in the door
Actually if you can use a screwdriver you can fix this problem yourself. The glass can be accessed by taking off the screws holding the inside panel to the door on. The screws are visible. Once this panel is off you will see the screws that hold the plate glass in. Keep in mind that the gasket that goes around the glass and inside the door panel are there to keep microwaves from escaping. So in all this be sure to put it back in place right. I have fixed many doors and there really is nothing to mess up. Just put it back together the same way you took it off but in reverse of course. As far as cleaning the glass there is a product call Goof Off that comes in a spray. They sell it at Lowes or Home Depot either one. Use steel wool that you can get there as well and spray a generous amount on the steel wool until it drips slightly and not on the glass directly. Clean all the areas and kinda of use a dry rag to wipe off any excess. After you've taken care of the rust stains and are satisfied take a good glass cleaner like Windex and clean it like regular glass. Keep in mind that the whole door will come off and completely apart to get to both glasses and in between. I would comment additionally that what is in between the glass may be that way due to a leak through the gasket around between the inside and outside glass. However, inspect the gasket well and if you need to you can find a replacement through the dealer or manufacturer of that brand. Keep in mind also that leakage from the microwave door in any way could hurt someone with a heart pacemaker if they get close or someone else that has a battery in it such as people with embedded health units for muscles spasms after back surgeries and the like. Those are the most critical health issues to consider and to be sure that your gaskets are good.
Jan 22, 2009 | Whirlpool MH1140XM Microwave Oven
The area between the glass on microwave oven door and the glass on then displays steams up while in use.
Be sure you always have the hood / vent fan on when using the microwave or the stove top.
Also, there may be a clogged filter. Check that.
Otherwise, I would be concerned that the internal cooling fan may not be working properly.
Aug 06, 2008 | Neff Microwave Ovens
Water has penetrated inside the door
Any water in between the glass and the door should evaporate eventually.
I wouldn't advise trying to open any seams in the door or removing the glass to get the water out as that would permanently damage your microwave.
Your models manual talks about steam/water condensation that gets trapped between the door and the glass and what to expect:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2007 | Emerson MW8107WA Microwave Oven
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 Door
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
1,408 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
