Question about Panasonic 50" 720p Flat-Panel Plasma HDTV
I have a 50-inch panasonic plasma tv that occasionally shows a solid black vertical bar near the center of the TV screen, 3 inches wide, from the top of the screen to the bottom. When the bar goes away, I can see distorted color lines, especially red, where the bar was. This problem is getting worse. What is causing this and what needs to be done? My manufacture's warranty expires in November, 2010. Any help would be appreciated. Thank you. John
    Top Expert:
  • Panasonic Master
  • 24,725 Answers
So the warranty expired in 2010, some 7 years ago!
The Plasma driver chip driving the centre portion has failed.
There is one cure, replace the screen.
Posted on Jun 20, 2017
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
  • 563 Answers
SOURCE: I have a verticle black line about 3 inches wide on my panasonic
Normally when a line appears on the screen of a plasma or LCD it indicates the TV needs repair. There are circuit boards inside the set that, if bad, will cause problems with the picture. The only troubleshooting the manufacturer will offer is to unplug the TV for 30 minutes. If that doesn't solve the issue, the unit needs service.
Call Panasonic at 800-211-7262 to see what they're willing to do for you. If you're under warranty they will service the TV for sure. If you're out of warranty they still might give you a break--they've been known to do that.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
  • 380 Answers
SOURCE: solid black vertical line
You could have one of three problems. One is really expensive to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went bad. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable2_bing.gif and clean it off a bit and put it back. If its still there, you have a deeper problem.
The buffer boards are located across the bottow when you take the back off. About 3 inches wide. Sometimes they are on the top as well.
Posted on Dec 06, 2009
  • 31 Answers
SOURCE: Panasonic TH-50PX60U 50 in. HDTV Plasma
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV.
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Posted on Apr 04, 2010
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My TH-50PZ80U has developed a vertical black bar, about 3 inches wide, at the far left margin of the screen. How do I get rid of it?
Need to know if the bar is cutting off picture or if the picture is being squeezed to fit the remaining space
Nov 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Black vertical bar about 4 and a half inches wide down center of screen
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Picture just has black bar down the middle of the screen.
That is probably a faulty segment display.
Replacing the screen will fix it.
Dec 07, 2017 | LG 50PC3D 50 in. Plasma Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic 50" 720p Flat-Panel Plasma HDTV Logo
109 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
