Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Replaced motherboard I still doesnt work freezer wroks but ref doesn't have to defrost w/hairdyers once a week
    President:
  • 2,468 Answers
Open up the freezers rear panel and check the defrost element for a bad heating element, that defrosts the freezers evaporator coil,then its either an adaptive defrost board which i suspect is controlled off the main-board that you already replaced
Posted on Sep 16, 2010
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Doesnt make ice. water side still works
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 18, 2011 | Refrigerators
Ice maker used to randomly stop making ice. Turning down the temperature and turning it off periodically both seemed to help get it working again. It stopped working again a week ago and made only one...
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 06, 2011 | Refrigerators
The freezer works but the cooler doesnt
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Frigidaire FRS26H5AS Side by Side...
The fridge was just working we moved it to a new location. We had to lay it down to move it, it was sat up for about a week and now we plug it up and it is not working. What could be the problem?
Leo Ponder
imufo2
Jul 30, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
One of the lower left freezer coils heats (turns red) a few times per week and water runs out the front of the frig.
Leo Ponder
imufo2
Jul 30, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker stopped working, doesnt let water in
Leo Ponder
imufo2
Jul 29, 2011 | Whirlpool Refrigerators
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Jul 23, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer of refigerator (coils keeps freezing over)
I had the same problem, i took mine outside and spayed degreeser on the coils and power washed it off. the coils get built up with dust. make sure you dont have it pluged in when power washing it. lol. good luck
Jul 28, 2007 | Hotpoint RLA80 Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
