What kind of ink roller does this model take?
  • 105 Answers
Compatible Brand Ink Rollers (6/BX) for use in Sharp EL1192BL Sharp EL1192G Sharp EL1701C Sharp EL1801C Sharp EL2192C Sharp EL2192G Sharp EL2192GII Sharp EL2192P Sharp EL2195
Posted on Sep 16, 2010
Need a wiring diagram for a Swann security camera model 642 3960 it has 9 wires what I cook the wire where the wires go do the wiring diagram
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
Mar 06, 2015 | SWANN Home Security
Ink ribbon el
It uses the IR-87T ink rollers.
Nov 20, 2013 | Texas Instruments TI-5045 SVC Calculator
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
2) Remove the printer cover. (Fig. 1)
pulling it upward. (Fig. 2)
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
How do I replace the ink cartridge?
Replacing the Ink Roller
1. Press OFF.
2. Remove the printer compartment cover.
3. Remove the ink roller from the right side of the compartment. Insert your
index finger, nail down, under the tab on top of the ink roller. Gently lift the
ink roller out of the compartment.
4. Lower the new ink roller (IR-21) into the compartment and align the hole
in the ink roller with the pin in the compartment. Press down until it snaps into place.
5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
Feb 04, 2011 | Texas Instruments TI-5006 II Calculator
WHAT INK ROLLER MODEL NUMBER FITS CANNON P23-DHV
Canon P23-DHVInk roller Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Thank you
Sep 30, 2010 | Canon P23-DHV Calculator
WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Jul 16, 2009 | Sharp EL-1801P Calculator
Need to find Ink Roller 2/color Canon Model # P23-DH Roller # CP-13 .
part# IR40T / CP-13
Feb 22, 2009 | Canon P23-DH Calculator
Ink gets carried over to subsequent sheets
More than likely your maintenance kit roller has been impacted with ink and is not applying enough lubricant to the drum. You can replace the maintenance kit and run cleaning procedures a couple of times to allow it to clean up.
Now the other issue is if you are using a third party ink stick. By that I mean non xerox brand ink sticks. I have seen those cause that problem more often than not.
Pull out the maintenance kit and see if the large roller, which should be a off white, is black.
Exacly what is happening is your maintenance kit puts a very thin film of silicon oil on the drum so that the ink does not adhere to the drum more than normal. When that roller becomes blackened, it isn't very effective and you get some of that residual imaging.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
