Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
What do i need to do reset lamp sony KDF-60XS955
    Sergeant:
  • 171 Answers
Here is the reset lamp timer guide
http://www.agoraquest.com/viewtopic.php?topic=31733&forum=70&keyword2=electronics
Posted on Sep 16, 2010
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
SOURCE: thermal fuse on sony KDF-60XS955
check out link below for part. i have 55cs955 and just ordered one. I still do not know where to find in TV but as most post says its somewhere near lamp housing.
http://www.partstore.com/Part/Sony/Sony/191002393/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDF55XS955
Posted on Apr 01, 2009
  • 8457 Answers
SOURCE: My sony grand wega kdf-60XS955 dont turn on
Power suppply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 08, 2010
rustym62
  • 201 Answers
SOURCE: How do you manually set the convergence on a Sony KDF-60XS955
lcd projection sets don't need a flash focus ...there is no convergence alignment. replacing the optical block should be all you need to do. the block contains the lcd panels with the picture already aligned.
Posted on Jul 09, 2010
toyladi3
  • 597 Answers
SOURCE: the green light blinked over 30 times and now the
Once your television starts blinking the green light, then it means there is a problem inside the unit.
the problem simply is a bad lamp that is why you are having a black screen.
The solution is simply for you to replace the lamp of the television with a new one. To replace this, you will have to unscrew the television open and try to remove the old lamp and fix in a new one. It is very easy.
If you are still having the blinking light, then it means it is not only the lamp that is faulty, there also is a bad capacitor on either the main panel or the power panel of the television that needs to be replaced.
Once the bad capacitor is replaced, your television will be in good condition once again.
Take care and good luck
Posted on Oct 25, 2010
Picture and sound go on and off every few seconds
If it is Sony KDF-60XS955 then its lamp is near to end and needs replacement.
Lamp replacement procedure would be written in user manual and its easy.
If tv model number is different than above mentioned, please let me know.
Jul 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tip
Sony KDF-60XS955 Service Manual Download
Download Sony KDF-60XS955 HDTV Service Manual
Models: KDF-60XS955 / KDF-55XS955
Have you misplaced your Sony KDF-60XS955 HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Sony KDF-60XS955 HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDF-60XS955 HDTV Service documentation.
I hope that helps.
_______________________________________________
on May 08, 2010 | Televison & Video
Tip
Sony KDF-60XS955 Manual Download
Download Sony KDF-60XS955 HDTV Manual
Have you misplaced your Sony KDF-60XS955 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Sony KDF-60XS955 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDF-60XS955 HDTV manual.
I hope that helps.
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I want to know where is the lamp section on this tv
Need to remove lower front panel of KDF-60XS955, lamp is located under lower front cover.
Click Sony Support and download user manual, check page-17 for how to remove front cover.
If TV model is different, let me know to provide you info accordingly.
Hope that info will help.
Nov 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tip
I hope that helps.
on May 08, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tip
I hope that helps.
Picture is dark even after ajustments
Is it Sony KDF-60XS955 TV and have you replaced its lamp?
Symptom shows TV needs new lamp.
Let me know if lamp is replaced or not to provide you more info.
Aug 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Thermal fuse on sony KDF-60XS955
Apr 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdf-60xs955 red continous blinking lamp light
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
452 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
