Question about Microsoft Xbox 360 Console
Disc tray will not open. you can hear it try to open however it will not
  • slickrick18 Nov 02, 2008
    my disk tray will opent i littel bit but if i pull they tray enought to put a game in there in no sound waht so ever on th 360
  • 25 Answers
If your Xbox is laying down.. first try standing it up or vise versa
if this doesn't fix your problem... contact microsoft and they will repair your console free of charge and send it back to you in about 3 weeks.
hope this helps :)
Posted on May 17, 2008
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
Nov 28, 2013 | Magnavox DV220MW9 DVD Player VCR
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 |
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
My disc tray will not open and sounds like it's running but locked.
On the front of the tray you should see a small pin hole, get a fine jewelers screwdriver or needle, next push it in until you hear a click, the door should pop open, now pull it out all the way and check for any debris or possible broken belt or slippage under tray. If you can't find anything try a disc to see if it will work, if yes! try the eject button if no! remove disc as outlined and have it checked out.
Jan 22, 2011 | Compaq Evo D510 PC Desktop
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
I put the disc in then its just says open tray.
Key what happens is that the disc tray doesn't close all the way. Take it to any place that fixes video game systems and they will fix it good as new.
Jan 10, 2009 | Microsoft Xbox 360 Console
Stuck disc (similar problem)
In the front of the tray there a small whole, try bending a paperclip straight with a small hook at the end and careully stivk it in that whole. Than gently try pulling it back thus opening the tray. Remove your disc and do not put any other disc in it but try to close the tray by using the button. If it closes, try to reopen it.
Check your disc for any dirt or perhaps some remains of stickers.
Be carefull with homemade discs, they might have a stickered label on it which can cause problems such as getting your tray stuck and not opening anymore ;-) .
Jan 05, 2009 | Philips HTS3450 System
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
