Question about Samsung LN32A330 32 in. LCD TV
Model lnt3242hx/xaa having a no signal problem not hooked to cable box other tv works when hooked to the same cable
SOURCE: "No Signal" when DVD player is hooked up via component video
That is the solution, thanks. Also in the video settings in your dvd player menu select which cables you used to hook up to the tv. Y Pb Pr
Posted on Oct 07, 2007
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Posted on Oct 17, 2007
  • 113 Answers
SOURCE: no signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
-Josh
Posted on Mar 05, 2008
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
  • 905 Answers
SOURCE: Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Posted on Nov 27, 2008
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
SAMSUNG LNT3242HX/XAA REPLACEMENT SCREEN
Replacement displays are the most expensive part of the TV and getting a new one will cost more than a replacement TV. You can check on Ebay for a unit that will not power up and you may be able to get a screen cheap enough but it most cases if the screen is broken then the TV is not worth repairing. Sorry
Jul 24, 2012 | Samsung Televison & Video
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
Hello my samsung hcn529wx/xaa is has a green picture,I switch my cable boxes and no help, when i disconnect cable box, i get a green blank screen instead of white,i went into the menu page and adjusted all...
If you have a DVD player you can do a test to see if you have a bad tuner in the TV. Using Red, White, and Yellow cables hook up your DVD player to the corresponding jacks on the back of the DVD player and INPUT on the back of the TV with corresponding jacks as well. Turn on the DVD and TV and go to the TV menu and find the input that you have the red, white, and yellow jacks hooked to and see if you get a picture from your DVD player. If you do get a picture you probably have a bad tuner in your TV (if you are sure your cable signal is good). This setup bypasses the tuner. Let me know how it goes. And if you haven't done so be sure you have the right input for your cable signal correct in the menu as well.
Dec 22, 2011 | Samsung HCN4226W 42" Rear Projection...
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
My samsung tv model number code LNT3242HX/XAA . Will not pick up any channels. I use to pick up all the local channels. Now it gets nothing!~! please help.
This can be one of a couple of things. If you had the power go out it is possible the tv just needs to rescan the incoming signals to find the channels. It's also possible that the video source was changed so that perhaps it is looking for a signal where there is none. ie it should look for cable but is looking at aux input and not seeing anything. If you are seeing a blank blue screen this is probably all that is wrong. You need to go into the menu then setup and select source and then scan the channels. This will be in your owners manual and is easy to do. Usually you only ever do it once when first you get the tv.
If that checks out and you are sur eyou are getting a incoming single then the tv reciever section may have failed. When you have ruled out the souurce then you may need to take it to the repair depot. You should contact smasung and get the closest repair dpot location. You can just go to the webpage and look under support to find and then call and see if they will give an estimate. The repair cost could get close to what a replacment tv would cost.
Aug 11, 2010 | Televison & Video
I can watch movies on my samsung LNT3242HX/XAA but I am unable to see or hear anything if i hook it up to cable, i know something needs to be replaced but not sure what? the tuner maybe?? ;p
1. Make sure you have connected the cable to the correct input on the set.
2. Access the User Menu and do a "Scan for DIGITAL" channels.
That should do it...
Jun 13, 2010 | Samsung LN-T4065F Television
Connection for digital signal box
You'll need a coax to twin lead transformer that you can buy from Radio Shack.
Feb 19, 2009 | RCA Televison & Video
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Samsung LN32A330 32 in. LCD TV Logo
113 people viewed this question
Jerry Greenberg
Jerry Greenberg
