Question about Asko T731 Electric Dryer
Too many rpms, how do i slow my dryer down? t731
  • selby4sale Apr 29, 2012
    I have this exact same problem. Did you find a solution to the problem that you can share? The drum is spinning too fast preventing the clothes from tumbling.
Posted on Apr 29, 2012
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
The first thing which comes to mind is this, have you brought this machine into north america from overseas ?
I ask because this is a problem which can manifest from the motor operating on 60hz cycle but designed for a 50hz cycle.
The drum will actually spins too fast hence the items don`t tumble but rather stay pushed to the perimeter of the drum...thus not drying.
If you open the door and run the dryer, the drum on an Asko T731 dryer should rotate at 52rpm. I use a piece of tape on the drum to keep count.
Let me know what you find and we`ll go from there.
Regards,
Macmarkus :)
Posted on Sep 16, 2010
Asko T731 Dryer rollers
http://www.askona.com/customer-care/resources/manuals
Sometimes there are spring clips that require a bit of prying before they pop free. Contact mfr for a parts diagram, that will show all of the parts and how they go together
Jan 06, 2014 | Asko T731 Electric Dryer
ASKO T731 Dryer
you will need a current meter to help me trouble shoot your unit. it is heating but not enough.
we will monitor how long the heater works and how long it is off.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Asko T731 Electric Dryer
No led light how do you check fuses?
Unless im mistaken they are in the back and cover needs to come off, see this picture.
Jul 26, 2008 | Asko T731 Electric Dryer
How do i replace the belt on my asko t731
open up the back panel it is usually right ther and easy to do
Sep 07, 2011 | Asko T731 Electric Dryer
I have the T731 butterflying dryer. It appears to be locked in the 15 hour time delay. How can I get this to start drying now without the delay?
I believe you have to press down on the start button and hold it till the time it's set at appears. Then you can change the time. If that does not work, then unplug for a minute then plug back in. -Tom
Aug 20, 2010 | Asko T731 Electric Dryer
Asko T731 Electric Dryer - where are the fuses on the back of the dryer?
Welcome to Fixya.
Before starting...
**Turn off your breaker at the home service panel, it should be a 30amp switch or unplug it from the wall...safety first**
The fuses are at the back located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, reliableparts.ca etc.
Asko part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Aug 05, 2010 | Asko T731 Electric Dryer
ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Dec 05, 2009 | Asko T731 Electric Dryer
Asko T731 sensor suuts off the dryer prematurely
you need chek are clean folow:
1-line chute assembly.
2-housing blower.
3- pipe duct .
Oct 05, 2009 | Asko T731 Electric Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Asko T731 Electric Dryer Logo
127 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
