Question about General Electric GSC3500NWW 24 in Builtin Dishwasher
There is a bad odor coming from the area of the dishwasher and I think the trap smells and needs to be cleaned. How do I do that?
  • General Elec... Master
  • 43,501 Answers
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Posted on Sep 16, 2010
The dishwasher smells
proceed according with the instruction manual for to clean,
see this web page for proceed too.
God bless you
http://www.ehow.com/how_2002482_clean_dishwasher.html
May 11, 2012 | Miele Optima G2470SCSF Dishwasher
Should there be a little water left in the dishwasher
yeah there should be a bit but the bottom should also have dishwasher salt in there. this is the bottom. the salt helps kill smells also helps cleaning. when you bought the dishwasher it should of come with a funnel thats for filling the salt into the system.
Jun 08, 2017 | Frigidaire FGHD2433K 24 in Builtin...
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
Very bad odor from the washer kind of musty smelling
There may be something in the sump to large to get chopped up that may need cleaned out. Below is a link to clean out procedures for your model.
The alternative to taking it apart is buy a product called Affresh for dishwashers, there is a green package for clothes washers and a yellow package for dishwashers. It works well to clean out the machine and odors left behind. It is typically available where you buy detergent in the same area.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 25, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
Mar 17, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool front load model#ghw9100lw2 Sour smell in trao
TRY RUNNING A COUPLE OF HOT LOADS(EMPTY) WITH DISHWASHER DETERGENT THIS WILL HELP BREAK UP THE MILDEW BUILT UP IN THE MACHINE
DO NOT USE DISH SOAP!!!!!!!
Feb 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Odor will not go away.............
hi there,
i would let you try putting a small can with charcoal in it inside the dishwasher. However, you cant use it for about 1 weeks' time.
Charcoal absorbs trapped smell.
hope this helps.
Feb 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
General Electric GSC3500NWW 24 in Builtin Dishwasher Logo
1,712 people viewed this question
Top General Electric Dishwashers Experts
Tom
gbob59
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
