Question about D-Link DI 514 Wireless Router (DI-514)
Pls. what is the ip of d-link model DWL-G700AP . TNX.
  • abhilash subramanian Sep 16, 2010
    if the dlink is connected to your pc and if u r able to access internet then you can find the interface ip by going to start->run->type cmd ->in dos window type ->ping and press enter.the default gateway number is the ip for the dlink.remember this is dynamic ip.If you want static ip u need to speak with ur internet service provider for setting it up on the d-link
    Problem Solver:
  • 17 Answers
The default ip address of the router should be 192.168.0.50 unless it was changed. If this does not work you can reset the router by pressing the reset button in on the back of the router for 5-10 seconds. Then this IP address should work to sign into this router.
Posted on Sep 16, 2010
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
How can i find the ip address of my Wireless Access Point device? (model DWL-G700AP)
Hi, here's how you can find your access point's IP address:
The access point is also your default gateway, because it's the device that you use to access the Internet, right? Open up a command prompt window (go to the Start menu, click on Run, type "cmd" and then hit Enter) and type "ipconfig" and hit Enter.
A bunch of information will appear. The one you want to look for is the one called "Default Gateway." The IP address that appears following "Default Gateway" is your access point's IP address.
Please rate this solution based on how helpful it was. (If you still can't find the IP address, add a comment and I'll be happy to reply.)
Sep 18, 2010 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to reset my DWL-G700AP by holding in the reset button and can not connect to or ping via 192.168.0.50
Under Windows 7, press the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Jun 22, 2010 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
But the DWL-G700AP...
Is this access piont connected to a router? Can you get online through the router? If you can go online through the router also check the status of your wireless connection. Make sure its connected and it's getting a valid ip address.
Aug 22, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
D-Link DWL-G700AP Access Point
You need to connect the access apoint directly to a pc with a CAT5 cable then set up a static ip on the pc which I assume you know how to do it, for the static ip put 192.168.0.5 subnet is 255.255.255.0 and gateway is 192.168.0.1 then save the settings, then check first if there's a good connection between the access point and pc, go to the command prompt then type PING 192.168.0.50 if you receive 4 replies go now open the http://192.168.0.50 if you receive 4 request time out reset the access point and and ping it again if still 4 request time out after you reset it replace that access point.
Jun 06, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Factory reset dwl g700ap
Bill,
I have here the steps on how to reset your device.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Jun 05, 2008 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
D-Link DI 514 Wireless Router (DI-514) Logo
85 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
