Question about Philips Magnavox 20MT133S 20" TV
Sub titles wont turn off
I have a magnavox tv with the original remote
how do i get rid of the sub titles?
It has the word su/title button on the remote, but when i push it nothing turns off
HELP!!
  • Philips Master
  • 5,568 Answers
It may sound simplistic but many times when a remote starts to act flaky, replacing the battery (or batteries) will cure the problem.
They don't last forever.
Another possibility is that the Closed Caption feature has been set in the menu so a check of basic settings might help.
Finally, the contacts in most remotes consist of small carbon buttons and fixed contacts on a printed circuit board.
The board contacts were once flashed with gold plating but - well, we know what has happened to gold lately, so manufacturers have pretty much ceased to use gold and some don't even bother with nickle now but just depend on the tin-lead solder to last beyond the warranty.
This latter material does oxidize over time and becomes a lot less conductive.
If you can crack the case (sometimes there is a concealed screw or two- be careful) it can help to gently run a pencil eraser over the board contacts to restore their shiny surface.
Posted on May 17, 2008
Cannot get rid of sub titles on the TV the button that should remove them does not do anything
Subtitles are embedded in the program material. You may be seeing closed captioning (CC) which usually is enabled/disabled as part of initial set up.
Aug 29, 2016 | Televison & Video
How to turn off sub titles using urc7110 remote
You probably have closed captioning (not subtitles) enabled. Closed captioning is enabled/disabled as part of initial set up.
Jul 11, 2016 | One For All Televison & Video
How do i get rid of sub titles
With your remote control. There is a button to press. The button has a picture of a TV screen and a line of dots along the bottom [....] Press for on press for off
Jun 03, 2013 | Sanyo Televison & Video
Sanyo tv
What is the exact model number to your Sanyo TV?
Jun 03, 2013 | Televison & Video
How do I get subtitles off
you can use the remote controller to off the sub titles set up or in the menu button of your tv.
Aug 28, 2012 | Televison & Video
How do I delete caption-sub-titles-from the screen. I followed the instructions from the ATSC converter box booket but can't remove the captions.Help!!!!!
U have the tv original remote,Yes tries that too,some time it is not from the tv DTV converter board Closed Captioning it is on but the tv set itself Close Caption like CC 1,2,3... it is on,it must be shut all to off only by a tv original remote like pressing the CC button on the remote couple times for all CC 1,2,3... to all off.Try website like Remotes.com to buy the tv original remote to used.
Jun 17, 2011 | Venturer Televison & Video
I have a Sanyo 19 inch tv and some how the sub titles got turned on and I cannot figure out how to get rid of them, I do not have the user manual Please HELP!
Its called closed captioning. You should be able to access menu options via a button on your tv or remote. There should be a way to turn it off in your tvs menu.
Mar 24, 2011 | Sanyo Televison & Video
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
Subtitles will not remove from t/v even when subtitle button is pushed on remote control
The sub titles are being generated by your Cable box or the Sat box. Sub titles are generated from two different sources: Cable Box,Satellite Box,U-Verse Box etc.
Check the settings in those sources and make suer the sub title is turned OFF in the tv set.
Apr 16, 2010 | Televison & Video
Sub-title does not appear.
It's called "closed captioning" and should be under the menu/setup button. Subtitles are only for DVD players.
Jun 24, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Philips Magnavox 20MT133S 20" TV Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
