Question about Hitachi 32UX01S TV
My Hitachi TV model 32UX01S turns completely off radomly. It does not turn back on without pulling the cord out of the wall and replugging it back in. It then appears to reset itself for at loeast a short time. Until the plug is pulled from the wall, on/off switch will not work at all. At times it seems the TV's ability to stay on is effected by volume of programs playing or even vibrations of someone jumping in front of the TV. Would like to know if there is an easy solution other than replacing TV.
SOURCE: Hitachi P42H401 - No Picture or Sound. Some Menus work.
find and push the "reset button"
Posted on Sep 02, 2007
  • 556 Answers
if you are a tech person please check 1 power supply output voltage is ok. 2 if it is ok check for horizontal section. `generally tv goes defective due to moisture specially in rainy season. problem is not much serious. good luck
Posted on Sep 19, 2007
  • 4 Answers
SOURCE: MY Hitachi 50v500 is shutdown itself
possibly a bad power supply board.
Posted on Oct 26, 2007
SOURCE: Hitachi 27AX1B immediately shuts off at startup
you are going into shut down check regulator check for bad solder connections get back to me
Posted on Nov 02, 2007
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
Remote code needed TV: Hitachi 32ux01s Remote: Sony RM-V220 .....?
My code(s) are: 10156,10030,11145,11156 & 10092. Hope this works for you(:
Feb 12, 2015 | Hitachi 32UX01S TV
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Could a wire have broke off inside the back of my older model 50inch hitachi tv,with the bigger backside,when the cable cord was pulled out of the back, instead of unsqrewing it fromits connection? th
No. No wire should come out. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sep 05, 2014 | Televison & Video
Unable to capture good image in PAL/SECAM region on Hitachi tv model No. 32UX01S
Some versions of this set will have only NTSC color system. They are meant to use with countries like US and others. Check whether your TV is multisystem compactable. That is, whether it can recive PAL/SECM/N.NTSC. You can get this details by its user manual. If you have its manual, refer it. If not, download it from here.
Jun 09, 2012 | Hitachi 32UX01S TV
My television just went off! We tried to turn it back on but it wouldnn't come back oh. Finally the button flashed red like it was trying to come on and we heard 2 or 3 words then that was it.then the...
Tries tv unplug,replug it back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If it have the same result.Yes,the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Hitachi P50H401 50 in. Plasma HDTV
After a storm, my TV will turn on and off, but it has lost its picture and it has lost all volume. I do not have it plugged into a surge protecter. Before I open the back and look for fuses, I thought...
post model number, take ac cord out of your tv & any cable or sat box you may have for 1 minute then replug tv & box to re-boot the micros, if still nothing set will need tv tech, gl, video-tek
Jun 10, 2009 | Hitachi Televison & Video
Hitachi 50v715 model
Step1 Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely. Step2 Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb. Step3 Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver. Step4 Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down. Step5 Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place. Step6 Tighten the screws. Do not overtighten them; they should be finger-tight only. Step7 Close the door. Make sure it is closed completely or the TV will not operate.
it depends on if your a handyman
Sep 24, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture is thin.
Looks like you have a problem with the Vertical Output stage of the TV. Unless you know something of solid state Electronics servicing , there is nothing you can do.
May 13, 2007 | Hitachi 32UX01S TV
Tv went off by itself
When you turn the tv on all the voltages come up for a second but the power supply is sensin a problem and it kills the high volatge and other voltages.One of the voltages the supply sends has a short.The tv needs to be service because components need to be checked and then replaced. Be safe and Seek the help of a technician to diagnose the problem.
Oct 01, 2006 | RCA D52W19 52" Rear Projection Television
No picture
A loose conection in the vertical circuit is likely,call someone to look for it and resoldered it.
Sep 09, 2006 | Hitachi 32UX01S TV
Hitachi 32UX01S TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
