Question about NetGear WN802T Router (WN802T-100AUS)
Ip address - NetGear WN802T Router (WN802T-100AUS)
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Can someone show me how to change my Dell lattitude e5520 ip address?
Your IP address is assigned by your network system.
If you have a conflict with your IP, you can try a ipconfig /release or ipconfig /renew.
At the command prompt type
ipconfig /? for all available switches.
If you are using a cable modem, you would want to reset to factory first.
May 03, 2014 | Office Equipment & Supplies
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
What is ip address and how can i change it
An IP address (Internet Protocol Address) is a logical address of a network adapter. The IP address is unique and identifies computers on a network. An IP address can be private, for use on a LAN, or
public, for use on the Internet or other WAN.
You cannot change the ip address, if you using static ip address.If it is dynamic ip address, you can change it easily by resetting the modem or switching it off and on.you can also use Proxy server or Hide ip address software to change the ip address.
To check the ip address before and after changing, you can visit the site Ip-details.com. Here you can search IP,domain host and it also includes city, country, global latitude & longitude coordinates etc.
Sep 20, 2012 | Brother MFC 7840W Printer
Ip address or INTERNET PROTOCOL address unique address for computer that assigned to internet ,Internet Ip-address provide by ISP,,Each device has it ip-address so that it can be easily identify by their ip-address...You can check the ip-address at here Ip-details.com
Dec 19, 2011 | Computers & Internet
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
NetGear WN802T Router (WN802T-100AUS) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
