Question about Vacuums
Hoover Alyx Pets 2000w Hoover Model TC1208 001 Virtually no suction, have checked for blockages but cant seem to see any, however i can't remove the hose to check it. Any ideas?
  • nick685 Apr 27, 2009
    NO suction- no blockages on the Alyx. Beats me- there must be a leakage in the sustem- can't detect it- the machine minus the cyclone sucks hard.
Did you check the HEPA filter? I have the same problem with mine if I don't clean the filter after using it. It's a dirty job but helps for a while.
Posted on Jan 02, 2010
Not getting any suction. there are no blockages.
Posted on Jul 21, 2008
The Hoover switches on and the brush rotates but the actual Hoover doesn't come on?
Hi, is there suction when you open the top of the wand handle?
If no, have you emptied the container. next check the tubes that are removable, you may find there is a blockage of hair and bits, have you removed filter and given it a goos wash.
Jun 04, 2014 | Dyson DC25 All Floors Bagless Upright...
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Freemotion Pets 200W has lost most of it's suction!
if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
Jul 31, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
No instructions
I need a manual for my hoover alyx 2000w model No TC1202 001
Jun 05, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
The vac just goes red hot and switchs itself off no idea why. alyx pets 2000w is the model of the vac.
Its activated its thermal cut off. Check the filters - if the paper pleated cone filter is blocked throughly tap it gently to loosen dirt before washing it completely and drying it in a low temp tumble dryer (put it in a pillow case with a towel inside the pillowcase to stop it knocking off the sides in the dryer.) Also check the main dust channels behind the bin and also behind the beater bar as it may well be clogged. Then reinstall everything and check again.
Mar 04, 2009 | Vacuums
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Nov 02, 2008 | Hoover Vacuums
Freespace pets cylinder hoover 2000w tfc6207
It is possible that the belt is broken.
Dec 31, 2007 | Vacuums
Vacuums Logo
922 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
