Since Fuji Finepix A120 is an older model camera so it is possible that its hardware would not support such big capacity memory card, however you can check this 2GB card by following method if that card will work in your camera or you need less size memory card like 512MB etc
Memory card is new so it needs to be formatted in camera to save picture files on it.
Press Menu button on camera and select Setup and press Menu/OK to display setup menu.
You will see Format option, select it and press OK to Format memory card in camera.
If camera still gives error of Not Initialize then its clear that camera hardware is unable to support that big size memory card, get less capacity memory card to use it in this camera.
Hope these info will help you.
Let me know if you have additional related question.
Thanks.
