RE: front load Kenmore washer Model 417.43142200: Can't get cold water into machine. No matter how I set the controls, the machine fills with hot water only. I have excluded the water supply as the problem and have confirmed the hoses are patent and connected correctly. I am willing to do repairs myself but need to know which part needs replacing. Can you advise? Thanks, Paul
    Brigadier General:
  • 8,619 Answers
Hi Paul,
Thanks for using FixYa. From what you have described the issue seems to be with the water inlet valve going bad as This Washing Machine Water Inlet Valve Has Two Ports for Water to Enter one for the cold water and another for hot, so it seems the cold one has gone bad and you'll need to replace the water valve to solve this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Why is my front loading kenmore washer making a very load high pitched noise when the water is filling into the machine? model #796 40311900
Here is an extract from my 'poor cold fill' guidance notes- worth following! Otherwise it could be the inlet valve not opening completely- maybe due to calcium?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB giving incorrect voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 12, 2011 | Kenmore Front Load Washer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
IS A HOTOINT FRONT LOADING WASHER TYPE WF860G [SUPER SILENT] MODEL A HOT/COLD FILL OR COLD FILL ONLY.
This model like most new models are cold fill only.. It will heat to the temperature set by the variable thermostat setting..
Dec 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Apr 17, 2008 | Kenmore 44042 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
