Question about Taylormade r7 Draw Fairway Woods
Does the instruction manual for the r9 driver with fct and mwt features apply to left handed golfers? Specifically, to compensate for a left slice, is the fct correction position 'r', and mwt position in the toe.
What is the difference between N and NU in the setup of my r9 taylormade driver
From the link below:
Locking the head back in place with the torque wrench supplied free with the club, gives me four main settings to set up the trajectory:
*Towards L sets the club to give a maximum draw (presumably for those with a built slice or fade swing).
*Towards R sets the club for a controlled fade (for those who consistently over draw or pull tee shots)
*Neutral Upright (NU) delivers a slight draw (for those with a tendency toward a slight fade)
* Neutral (N) produces a slight fade (my preferred setting to counteract an occasional hook/pull)
Long term test TaylorMade R9 driver
Dec 02, 2014 | Taylormade R9 SuperTri Drivers
How do I fix over exposed pictures outdoors
Check and make sure you don't have the exposure compensation settings set higher than 0. There is a manual override feature that lets you apply over/under exposure compensation to every photo rather than manually setting it for each shot. Sometimes, this feature can get accidentally changed. If that's not the issue try to reset the camera back to its default settings through the menu feature.
Aug 07, 2014 | Canon EOS Rebel XSi Digital Camera
How do you change to a left handed golfer on the ps3 move for tiger woods PGA TOUR11
The game does not allow you to change this option, this is chosen in the settings when you first create a golfer, but unable to change later.
Apr 03, 2011 | Sony Video Game Consoles & Games
How do you make the webcam low light compensation work?
Hello iarharmandee. In order to fix your issue with the low light compensation feature, please follow these quick steps:
Open the included webcam software as bundled with your Acer laptop.
In the program, click on the Properties dialog box. In the Properties window, click on the Camera Control tab. To use the Low Light Compensation feature, be sure to select the Low Light Compensation check box Hit Default to make your adjustments. Click OK or Apply to save your settings.
You should be up and running now with full functionality of the low light compensation feature.
Feb 27, 2011 | Acer Computers & Internet
Clear instructions for power plus 24 hour timer. What is meant by slices ?
I can't identify 'power plus' timer specifically.
I'm going to guess at answer based on other manuals.
Your timer has a dial on it's face. You rotate dial to set time of day. And the time of day lines up with a triangle marker usually located on center part of dial on right side.
The dial has 48 plastic pieces around outer edge of dial, and each one of these 'slices' or pieces of plastic represent 1/2 hour.
So the dial has 48 'slices' around the dial, and each 'slice' can be lifted up to set timer on-off functions. Sometimes they lift up and out instead of straight up.
Usually when slice is up, timer is ON, and when slice is down, timer is OFF.
Oct 02, 2010 | Hardware & Accessories
I bought an r9 supertri driver and need the manual for it. any ideas?
Movable Weight Technology TM, is discretionary clubhead weight that can be easily redistributed by the player to change the characteristics of the club. By moving differently weighted cartridges, using a proprietary TaylorMade wrench, into strategically positioned ports, CG location can be optimized per golfer. Positioning more weight in the heel and less in the toe, speeds club head rotation during the forwardswing, which promotes a draw and/or reduces a slice.
Here is a link that will definately help you with the adjustment aspects of your club:
http://www.taylormadegolf.com/mainlevel/golfshop/drivers/R9-SUPERTRI.html#30
Aug 12, 2010 | Taylormade r7 Draw Fairway Woods
Don't know where the weights go for a draw
With R9, they tried to maximize the fitting possibilities for each golfer. They engineered two independent and complementary adjustability systems into the head to cover a large range of ball-launch conditions. They use movable weight technology in combination with a variety of head angles and seamlessly integrate them into a beautiful shape"
The 430cc head features "flight control technology" (FCT). Simply, an adjustable head-and-shaft system (tighten the recessed titanium screw to an aluminum "sleeve" on the end of the shaft) gives you the ability to lock the head in eight different settings. The shaft (and "sleeve") go into the hosel off-axis by 1°, which allows you to tweak face angle (2° closed to 2°open), lie angle (1° upright to 1° flat) or loft (1°stronger or weaker than stated loft). Company brass says FCT produces up to 40 yards of directional flight variance. That's particularly good news for slicers or hookers. FCT combines with the firm's "movable weight" technology (three removable plugs that weigh 16 grams, 1 gram, and 1 gram) to generate as much as 75 yards of left-to-right shot bias, 3° difference in launch angle and 1,500 rpm of backspin. Fit yourself by positioning the face angle (FCT) and then move weights to dial in trajectory.
Oct 17, 2009 | Taylor Instruments Taylor Made R7 Quad 9.5...
Can a left handed golfer
Yes, you can.
Source (in a customer review)
Enjoy :)
Apr 14, 2009 | Mad Catz Real World Golf Bundle for...
Nortel M7208 eliminate intercom button
You have to go in to main system programming , It is best to use a M7310 phone if you have one . Press Feature ** 266344 when it ask for a pass word re-enter 266344 . First go to terminals & set and enter the ext you want to program press the show button then press the next button until you get to intercoms . press show then press the change button under the soft key until you get to 1which will be the new number of the icm on the phone . Now you can program a feature on it .
Apr 01, 2009 | Nortel Meridian M7208 Corded Phone
Taylormade r7 Draw Fairway Woods Logo
320 people viewed this question
Top Taylormade Sport & Outdoor - Others Experts
Are you a Taylormade Sport and Outdoor - Other Expert? Answer questions, earn points and help others
