Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
How do i use SATA to recover my data from my WD 500 gb mybook? you see my power source is working at all.
  • 11,800 Answers
You dismantle the case and extract the hard disk. Then you take that disk and you put it in a desktop pc (you will need a SATA dat cable, a SATA power cable and 4 small screws tu secure the disk inside. Once it's installed just start the pc and open My Computer - the disk will be there, copy from it whatever you want.
Posted on Sep 16, 2010
I have a WD 500GB MyBook and it stopped working last night. The round power light still lights up when i turn it on, but there is no spinning sound from the drive like it usually does. I wonder what is...
TRY TO LISTEN.IF THERE IS SOME THNG RUNNING.IF NOT >SWITH OFF >CHANGE THE CABLE >TRY AGAIN >IF YOU DONT HAVE NEW FIT THE CABLE TIGHTLY.ANY HOW YOU SHOULD RECOCKNISE TO THE MOTHER BOARD.IF *********** BOARD RECOCKNSE DOWNLOAD STELLER PHONIX.JUST PASTE YOU CAN RECOVER EVERY DATA.
Nov 26, 2010 | Western Digital My Book Essential Edition...
It was working fine and then I went to turn it on
If you're connecting a known-good power supply to the MyBook, and it's not turning on... I suspect that the MyBook has died. You should replace it or have it serviced. If the data on it is very important, it might be worth taking the drive apart and removing the hard drive inside and trying to recover data. If the data isn't important, I would say the MyBook is dead. Sorry.
Feb 27, 2010 | Western Digital My Book Essential Edition...
How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Jan 28, 2010 | Western Digital My Book Essential Edition...
WD5000MT not recognized
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
May 21, 2009 | Western Digital My Book Home Edition 500...
My WD 250 GB ext. HDD, not showing data, but showing free space
files are there but data is not there & its showing file is empty
Feb 18, 2009 | Western Digital My Book Essential Edition...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
MyBook was working for about 1.5 years
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
Western digital my book 500 gb
Cheek your system os is not suportion the hard drive increase the ram and try in xp only
Jul 10, 2008 | Western Digital My Book Essential Edition...
The request could not be performed because of an i/o device error
here are some photo recovery software(also recover videos and music) for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the WD in case the original files(your pictures or vidies) are overwritten.
May 28, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
121 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
