Question about Toshiba Computers & Internet
I blow my line input when i record from my multi track recorder
    Genius:
  • 1,066 Answers
Turn the volume down???
Posted on May 17, 2008
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
Effects won't record or play back
Turn on the effect for the appropriate input or turn on the reverb. For the reverb you must turn up at least one tracks (the track you are using) effects send together with the Master effects return. The volume of the multi effect may need adjusting or the parameter of the effect is so low that the effect is too subtle to be noticed. Multi effect page 60 of the manual. Manual can be found at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 28, 2009 | Tascam DP01 All-In-One Recording Package...
DP-01 Wont Record
You may need to assign one of the inputs (a or b) to the track you want to record to. Do this by first pressing the 'Assign A' or 'Assign B' (if you are lining in a guitar to the Hi-Z input then you'll be using 'Assign A') and then press the record/select button for the track to assign. After doing this you'll arm your track for recording and proceed to record.
Hope this helps.
bd.
May 17, 2009 | Tascam DP01 All-In-One Recording Package...
Dp02 recording music(from stero)
Sounds like you are using the DP-02's 'stereo mix' inputs here. If so, the signal input from those is only routed to the line out and headphone jacks and cannot be recorded using the DP-02.
To record from a stereo you need to take the left and right aux outs (or some other line out - like the tape outs) from the stereo and put them into the main A and B mic/line inputs on far right of the DP-02's back panel. Then assign them to two respective tracks and you can record the stereo output to the DP-02. Just make sure you use a line level output from the stereo as the amplified speaker output can overpower and damage the inputs on the DP-02. You might need a couple of rca to 1/4 inch adapters to accomplish this.
Hope this helps.
bd.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
How do i recod on the ctk-900 casio?
Try running a line out from your keyboard to the line input on your mac. Go into system preferences, select sound, click the input bar in the upper right corner, select line in/Audio line-in port, then adjust your input volume. You should then be able to record from your keyboard. If this doesn't help you, please let me know. I'm a recording engineer that uses a MacBook for all my multi-track recording projects. Thanks & good luck. Mark
Dec 25, 2008 | Casio CTK810 61 Key Keyboard
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Don't know how to actually record
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Computers & Internet Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
