Question about Zanussi ZBF360X Electric Single Oven
The external glass on the oven door has broken. How easy is the replacement?
  • Zanussi Master
  • 43,501 Answers
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Posted on Sep 16, 2010
5 Suggested Answers
  • 833 Answers
SOURCE: Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Posted on Dec 07, 2007
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
Maytag317
  • 1136 Answers
SOURCE: Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 228 Answers
SOURCE: I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
Posted on Mar 04, 2010
Tip
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Jan 04, 2008 | Ovens
Zanussi ZBF360X Electric Single Oven Logo
322 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
