Question about Lands Phones
How do I turn the ringer back on a Vista 350 telephone.
3 Suggested Answers
SOURCE: Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Posted on Oct 08, 2008
SOURCE: BELL VISTA 200 TELEPHONE
how do I turn on the backlight
Posted on Jan 24, 2010
How to Turn ringer button on and off for a Panasonic KXT7433
Most of the phones have a switch on the side or end that is labeled ringer. You just move it to the desired position.
Dec 10, 2013 | Panasonic BTS KX-T7433B KX T7433B KXT7433B...
Ringer is off; how do I turn on?
see your owner manual where is located the RINGER . see it and turn ON. again.
God bless you
Oct 03, 2012 | Lands Phones
How do I turn off the ringer to my vtech, model6032 telephone.
Ring volume
The handset ringer volume can be adjusted from five levels.
• Press MENU/SELECT to display menu when in idle mode.
• Press up arrow or down arrow to reach Setup HS. Press MENU/SELECT.
• Press up arrow or down arrow to reach Ring volume . Press MENU/SELECT.
• Press up arrow or down arrow to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
• The screen displays Stored and you'll hear a confirmation beep.
You can adjust the ringer volume by pressing VO L+/VOL- on the
telephone base when the telephone is ringing.
Jun 30, 2011 | Vtech 9009111 Cordless Phone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do I turn off the ringer on my AT&T 832 telephone? I do not see a ringer button and I do not have a manual. The phone is about 12 years old.
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 14, 2011 | Cell Phones
How do I turn the ringer on? 5.8 EXI 5160 phone
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as
vol or vol) in standby mode to select one of five
ringer tones and volume combinations.
You can get the manual on link below page 19 will tell you how to set ringer volume.
http://www.uniden.com/pdf/EXI5160om.pdf
Dec 23, 2009 | Panasonic 5.8GHz Cordless Telephone
The ringer is turned off on my Cirrus 100 (onetel) telephone
I have the OT100 & to turn ringer off & on you press & hold down the * key until the phone beeps
Sep 02, 2009 | Lands Phones
G E Corded Telephone
The phone does not have batteries... it gets its power throught the telephone line cord.
On the side of the base of the phone there is a little button you can slide that will turn the ringer up, down or off.
Jul 09, 2009 | GE 29267GE3 Corded Phone
i need a manual for a vista 200 to programme it and to clear stored info i bought it second hand
Dec 05, 2008 | Bell BE-412CID Corded Phone
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
