Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
SET KEEPS TURNING OFF
THE SET WARMS UP, PICTURE COMES ON FOR A FEW SECONDS THE GOES INTO STANDBY FOR FORTY SECONDS. THEN THE CYCLE STARTS OVER.
  • 1 more comment
  • Anonymous May 30, 2008
    Comes on with great picture for about 40 seconds goes off and green power on light flashes about 30 times comes back on great picture and cycles thru this over and over.
  • Laura Stacy Jul 23, 2008
    EXACTLY The same problem. I see the response was something to do with a thermal sensor. Is that something I can fix so I can cancel the service call that is coming?
  • scotticidal Aug 03, 2008
    wow wow help? is thermal sensor hard to fix for a newb?
  • Sony Master
  • 8,617 Answers
Sounds like the thermal sensor is defective. They are usually located on our near the lamp assembly housing.
Posted on May 17, 2008
    New Friend:
How much did it cost to fix?
Posted on Feb 28, 2013
  • waca51
    waca51 Feb 28, 2013
    how much did it cost to fix?
    Problem Solver:
  • 5 Answers
I had to have my ballast replaced as well as the lamp again.
Posted on Aug 04, 2008
Hey ron did this work? replacing the thermal sensor? mine is doing the same thing.
Posted on Aug 03, 2008
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
100 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
