FixYa.com
Tags:
Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher shu3322uc/22 (by 3 users)
posted by usbturbo on May 17, 2008
(Bosch shu3322uc/12)Dishwasher is about 6 years old. It recently stopped cleaning the top rack of dishes. It is getting water to the top propeller, but not with enough force to make it spin. I have checked the tubes running up top and they are not clogged.Since the top arm does not spin the soap is not getting dispensed. Filters are also clean. Could the pump be going bad? If filters are cleaned do they have to be replaced?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 15, 2008
shu9915uc/u11
Comment by keithxgraham, posted on Jul 04, 2008
Hi, my Bosch DW (5 years old) has recently started playing up, some days the top rack wont wash properly but the bottom rack will and on other days the bottom rack wont wash properly but the top rack does. The water pressure within the DW is excellent, I have cleaned the filters, cleaned out and checked for blockages in the rotary arms, salt dispenser is full, rinse dispenser is full, but still cannot get the diswasher to clean top and bottom racks together!. Any clues please.
Solution #1
posted on Jul 03, 2008
Not Rated (0)
aehess
Rank:Wiz Wiz
Rating: 83%, 53 votes
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
drain pump will not shut off
I found the red plunger after I... Answer This...
Exact same problem
What is the base plate? I... Answer This...
dishwasher wont fill.
Washer runs but will not full.... Answer This...
There is a terrible smell in...
we can't get rid of the... Answer This...
BOSH SHU43 dishwasher
I have a Bosh SHU43 dishwasher... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
