Question about Linksys Wireless-G Broadband Router
Set up a password for the wireless system - Linksys Wireless-G Broadband Router
  • 6,831 Answers
Hello
OK, at the link below you will be able to get step by step instructions on how to secure your wireless network.
Click HERE.
Kind regards
Andrea
Posted on Sep 16, 2010
Forgotten password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 15, 2011 | D-Link DIR-615 Wireless Router
I never had a password for my router, but Today is has a password and I cant use it
I assume you are talking about a wireless router.
If so, then it is possible someone else has accessed your router's ADMIN settings through a wireless connection and has enabled the password feature. This can be done from a wireless computer somewhere inside your home, or even from one located outside on the street or from a nearby neighbours house. Normally this is done by wireless hackers to maintain access to your router and keep on stealing your internet signal bandwidth.
Luckily you can just use the RESET feature on your router to clear off any old settings and return it to factory new condition. Then you can set up your system again using your own secure ADMIN password and wireless encryption. I highly recommend you use the more secure WPA wireless encryption as opposed to the old WEP type which can easily be hacked.
Just look in your router's USER MANUAL for complete instructions on how to RESET the router using the small pinhole button on underside of router, how to set up an ADMIN password, and how to enable WPA wireless encryption on your system. This should secure your system and keep out those pesky wireless hackers.
I hope this was helpful, good luck and take care.
Joe.
Jul 20, 2011 | Computers & Internet
At my dad's house and he does not know his id and password
Once connecting the modem to power source, power on knob, using the computer add devices functionalities to reset the already existing password. First, consider logonning on to the computers wireless devices area on systems settings located on my computers, control panel button icons. Delete the prior account from the computer wireless settings. Powering off the computer thereafter, restarting after connecting modems should initiate default systems settings. First, consider reestablishing computer wireless connectivity. Choose not to set any passwords on new wireless networking setup, or the alternate. Whenever require help on computer system settings, hit the F2 function key to display a popup logo on which questions are searchable similar like internet seachr quests. Consult technical support for wireless connectivity. Good luck
Jan 10, 2011 | Linksys Wireless-G Broadband Router
Securing router from outside user.
Set wireless security to one of the options available. Also, set the router system ID, and change router login password, (record it somewhere, like on the actual router) change the wireless channel to 11 to avoid conflict with landline wireless handsets.
There are higher security settings, but wireless access password is pretty effective.
Oct 04, 2010 | NetGear Computers & Internet
Belkin wireless g mimo router. i never set a
When changing the advanced settings on the Belkin router, you should change the default password.
To change the password, go to Administrator Password. Type in a new password. Make sure you remember the password, otherwise, you will need to reset the router back to default settings.
I hope this helps.
Jun 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need to change password as it bein hacked
Log in using a wired connection to the router (probably 192.168.0.1 but if you right click on your conection and check the details it will be the gateway address) and go into the security settings and select the securilty system you want WEP or WPA. You will need to set up all the wireless devices devices to the same system
Apr 04, 2010 | NetGear WGR614 Wireless Router
I can't conncet to my wireless-G broadband router
you are trying to connect to the wireless network on a new wireless computer.
When you try to connect to the wireless network, it is asking you for the password. That means your You wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 21, 2010 | Linksys Wireless-G Broadband Router
Changing the password
  1. Select Configuration|Security from the Access Point menu tree.
  2. Select Modify System Password.
  3. Configure the AP password settings as required:
    System Password Select any alphanumeric, case-sensitive entry of up to 13 characters. The characters selected are displayed as asterisks. Changing this passowrd changes the Read/Write Community password found in the SNMP Configuration screen. The default password is Intel. Confirm System Password Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
  4. Select Save Settings at the bottom of the page.
Jul 02, 2009 | Intel PRO/Wireless 2011B LAN Enterprise...
Linksys Wireless-G Broadband Router Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
