Question about Johnson Plumbing
Cutting old johnson 3/4 steel pipe. Need conection, to enable conection to new blue pipe
    Problem Solver:
  • 13 Answers
The best option is to follow the steel pipe back to the next threaded fitting. Then install an adapter to convert to the plastic.
Posted on Nov 28, 2010
I have a Iver Johnson 12ga double barrel with 30" barrel's s/n 28586 How old is it and What is the Value?
These will all help you.
Iver Johnson's Arms & Cycle Works - American Firearms
www.american-firearms.com/.../Iver%20Johnson's%20Arms%20.../Iver%20Johnson's...
  1. Cached
  2. Similar
Aug 7, 2011 - Single top latch, 100'000 were manufactured in 1894, serial number without letter prefix, marked on the top of the barrel rib. IVER JOHNSON'S ...
*IVER JOHNSON SERIAL NUMBERS ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Jan 11, 2012 - 15 posts - ‎10 authors Is the gun large frame or small frame, hammerless or a hammer gun? ... I have a Iver Johnson Top Break 5 shot hammer gun. ... I just purchases an iver Johnson hammerless 5 shot top break revolver. Iver Johnson Serial Numbers 6 posts 26 Jun 2016 Iver Johnson Serial number help 15 posts 1 Nov 2014 Old Iver Johnson shotgun 12 posts 10 Nov 2011 Need Info on Iver Johnson Hammerless Revolver 15 posts 13 Apr 2006 More results from www.thefirearmsforum.com
Blue Book of Gun Values - IVER JOHNSON ARMS & CYCLE WORKS
bluebookofgunvalues.com > Gun Values
  1. Cached
  2. Similar
IVER JOHNSON ARMS & CYCLE WORKS gun model and pricing information.
Iver Johnson Arms - M1CarbinesInc.com
www.m1carbinesinc.com/carbine_ij.html
  1. Cached
  2. Similar
Introduction to Iver Johnson, Iver Johnson's Arms, & Iver Johnson's Arms & Cycle .... With the exception of the D-Day Carbines the serial number on Iver Johnson ...
manufacture date of Iver Johnson revolvers based on serial number ...
www.rimfirecentral.com > Other Rimfire Guns > Misc -- Other Rimfire Rifle Brands
  1. Cached
May 17, 2016 - 14 posts - ‎3 authors There is a serial number listing for the Iver Johnson SuperShot 22 Top Break Revolvers in W.E.Goforth's book/reference, "Iver Johnson Arms ...
Iver Johnson - Wikipedia
https://en.wikipedia.org/wiki/Iver_Johnson
  1. Cached
  2. Similar
Iver Johnson was a U.S. firearms, bicycle, and motorcycle manufacturer from 1871 to 1993. .... William McKinley in Buffalo, New York on September 6, 1901 with an Iver Johnson .32 caliber Safety Automatic revolver (serial number 463344). Iver Johnson 12ga Google Search
Nov 30, 2016 | The Optics
Change the cutting blade on mtd ride on mower
I run mine up on a wooden ramp I made out of two by sixes and lift the cutting bar as high as I can then use a Johnson bar with the socket that fits the bolt and get a piece of wood and put against the blade and frame and turn the bolt off. Sometimes you need a pipe on the end of the bar to give you more leverage if the bolt is hard to come off.
Sep 30, 2014 | Mtd Garden
1998 Cadillac Deville exaust cross pipe replacement
1) Take it to a muffler shop unless you are a good welder.
2) Procure the new exhaust pipe material.
3) Make the necessary bends in the new pipe to correspond with the layout of the old pipe with a hydraulic tubing bender.
4) Use a band saw to cut the new pipe to lengths using the old pipe as a template.
5) Weld the pieces to form the crossover.
6) Using a cutting torch, cut both exhaust pipes to the length you made the crossover.
7) Weld in the new crossover you just made.
8) If you can't weld with a torch, have no access to a tubing bender and have no way to get the correct exhaust pipe material....take the car to a muffler shop.
Sep 24, 2014 | Cars & Trucks
How do i cut cast iron pipe grey
you can get a steel cutting blade for a handheld circular saw and use that if you have room.. beware of the sparks also..this looks like a flat grinding wheel and runs in place of the sawblade.. it will cut through most metals..be very careful as it will spin very fast so hold slow and steady when cutting with it..
Jan 23, 2013 | Cars & Trucks
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Mar 28, 2011 | Husqvarna Garden
How to replace evaporator coil on rs267labp?
you will have to have soldering skill with a oxygen acetylene brazing torch.. first remove the coils either cutting the lines or aplying heat to the conection, they will come loose. then position the new coil and braze weld if its copper to copper use silver brazing if its steel to copper, or steel to steel you will have to use bronze rods.. however if the joint shall be aluminum to any other metal you will have to do some research on tha one .. hope to be of help...
Feb 10, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
Jan 10, 2010 | Proxxon 28174 24-Tpi Fine Toothed Band Saw...
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Replacing thermostat for kia sportage 2002
Where top water pipe is conected to the engine - rubber hose to steel pipe-- there is 3 bolts , loosen and you will finde the thermostat. Willem SA
Sep 16, 2008 | 2000 Kia Sportage
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Plumbing Logo
56 people viewed this question
Top Johnson Plumbing Experts
Donni Steen
Tom Chichester
Are you a Johnson Plumbing Expert? Answer questions, earn points and help others
