Question about Frigidaire GLMV169D Microwave Oven
The microwave will not heat unless you run it 5 or 6 times the normal time and even then it won't completely heat. This happened all of a sudden. What would be wrong with it?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 17, 2010
MY MICROWAVE IS NOT HEATING
If the microwave is turned on and you can hear the fan working when you set the time you should make sure of those things:1. You have selected the proper programme. Some microwaves have a control desiged to use the programs on the buttons. if you want to you the buttons to set time you should select "microwave" or a similar button and then press the power level like "1", "2" or "80", "100" (being percentage) and then press the buttons for timing.2. If you have used it for a while and it suddenly stopped heating the food, than it could be that your magnetron (a spare part) has burned out. Have a specialist replace it, or just get a new microwave, the price difference won't be that great for standard issue microwaves.
Feb 25, 2012 | Whirlpool Microwave Ovens
Panasonic NN-S752BF
You have a bad inverter. Time to replace the unit. The inverters are expensive and its cheaper to replace the unit. Unless your microwave is under warranty, and you can have THEM pay for it. I would say you have at least a bad inverter, and possibly a bad magnetron too. Good Luck!!
Aug 20, 2017 | Panasonic Microwave Ovens
Microwave doesnot heat anything
6 years is a good run for a microwave to keep working
as it is basically a high frequency radio transmitter, take it in for a proper diagnosis and a quote
mostly after 6 years there may be a shortage of parts available for repair so keep in mind that it may be cheaper to junk it and get a later model
Mar 08, 2017 | LG Galaxy Countertop Microwave Oven
Not cooking food even though it comes on
Check the power setting. You can tell if it is on a lower setting because it will cycle ( you can hear it humm lower for a short time then the sound is different and then it humms the same again. It happens...it is new.
Sep 02, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
Microwave not heating up
that has happened to me twice, the only thing that you can try is to change the setting to make sure that its not on DEFROST setting, and if this is fine, they I recommend U to get a new Microwave. :)
Feb 10, 2008 | Microwave Ovens
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
