Question about Sirius Stiletto 2 Satellite Radio Receiver
Receiver says acquiring signal - Sirius Stiletto 2 Satellite Radio Receiver
    Problem Solver:
  • 6 Answers
WILL NOT MOVE PAST Bell receiver warning 061 - Status: Acquiring Sattelite
Have a read of this page. Some say it is the cables to the LNB on the dish. Another said if is a hard drive problem and you need a new receiver.
Bell receiver warning 061 Status Acquiring Satellite Google Search
Aug 14, 2017 | Bell Televison & Video
Stuck on acquiring signal
Go outside, get a clear view of the sky to acquire a signal. Then try rebooting/reset the unit.
May 24, 2011 | Magellan RoadMate 1210 Car GPS Receiver
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
If it is reading "ACQUIRING SIGNAL" WHAT CAN THIS MEAN??
This typicall represents a failed antenna with either a loose connection or failed wire to the antenna. The "Acquiring Signal" indicates the receiver is trying to locate and decipher a signal from a sattelite. THe antenna is your first diagnostic. After that the receiver is the culprit. When your receiver is Activated or Authorized it is given a "key" to decipher the sattelite signals If it loses the "key" you can try and have Sirius reinitialize by contacting support. If they cannot send the signal and get the proper "Key" loaded its a defect in the receiver functionality.
Jun 15, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Sirius Stiletto 2 Satellite Radio Receiver Logo
1,283 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
