Question about RIM BlackBerry Bold 9000 Smartphone
My blackbery bold keeps shutting on and off every minute. i want to back up my data on top blackberry desktop manager, yet the phone wont stay on long enough to back up.
    Genius:
  • 1,416 Answers
What this simply indicate from our statement is that the phone has develop a power problem from the power supply(battery)connected to the panel.
However, there are different ways of going about this type of problem ,here are some guild line below which include flashing with a soft ware on computer
before you can apply the first solution above please try the below instruction
Carefully put of the phone for some time and then remove the battery if possible then put it on again after some time.but if this could not solve the problem.
Then you will have to unscrew the phone with the bass tools for phone to open up the phone clean up the pane carefully with a sprite solution (only on the panel)then couple it back to is position but if this fails then apply the bellow instruction.
You will have to take the phone to a very good phone work shop around you but for the flashing he/she will have to make use of USB cord to copy the data from the phone to save it in system (computer).
thank you and thanks for using fixya.
Posted on Sep 16, 2010
My blackberry keeps rebooting and and battery runs down in minutes
You will need to re-install a new OS.
Wipe your phone data, but first of all backup your data, then load a new os with blackberry desktop software.
Best regards
Aug 14, 2013 | RIM BlackBerry Bold 9700 Smartphone
Hey; i had a blackberry 9700, but it completly
Don't do that, desktop manager would not reset your mep counter since that counter is written on rom your phone and it's not allowed to access by using software. The only option that you have is doing cable unlocking in your phone and you only can do that at professional mobile repair shop. This method not only reset your mep counter but also unlock blackberry bold 9700 network so you can use any of your sim card without need to buy blackbery unlock code again.
Mar 21, 2011 | RIM BlackBerry Bold 9700 Smartphone
Blackberry solution for mep code (0 left) This is the solution for anyone have mep code 0 left in his handset that no attemt balance for enter code. 1. Please install black berry desktop manager....
That method will not work, wanna bet? The only way to reset mep code is doing cable unlock in your phone. This method not only reset your mep counter but also unlock blackberry bold 9700 network so you can use any of your sim card without need to buy blackbery unlock code again.
Mar 06, 2011 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry Bold 9700 will not power all the way on. I have a JVM error 102. It tells me to reset but it keeps coming back to the same error screen. Help please
All you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. Unfortunatly you will lose all data on the phone because you will be re-installing the software. If this doesnt resolve the issue then, this is a device issue. You will need to contact your service provider for replacement options.
Mar 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
Blackberry Bold 9700 - RELOAD SOFTWARE 513
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
Feb 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
Forgot password
There's noting you can do for now, back up your files and data using the Desktop manager and reinstall the software for your blackberry.
After that you can restore your data.
Regards
Feb 22, 2010 | RIM BlackBerry Bold 9000 Smartphone
My bold 9700 wont load pass the blackberry screen
Plug the phone into the computer after you have opened Blackberry Desktop Manager and one the phone is connected and it registers a pin on the bottom of the Desktop Manager software select application loader then choose update software.
Feb 16, 2010 | RIM BlackBerry Bold 9700 Smartphone
I have BB curve 8310 and it wont turn on at all, battery is charged fully and it is also plugged in. The light is on red and it stays on for 30 seconds than will flash once and go back on for 30 seconds...
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, such as this one.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 09, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
  1. In BlackBerry Desktop Manager on the computer, double-click the Back Up and Restore icon.
  2. In the Back Up and Restore window, click Advanced. The BlackBerry device database information will populate the right hand side of the window.
  3. Scroll down through the list and highlight Phone Call Logs, and select Clear. Note: If you are unable to clear Phone Call Logs, delete the Desktop [SYNC] service book on the BlackBerry device. This can be performed on the BlackBerry device by selecting Options >Advanced Options >Service Book and clicking Delete.
  4. Once the Phone Call Logs database has been cleared, disconnect the BlackBerry device from the computer, and then re-connect it to obtain a new Desktop[SYNC] service book.
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader in the BlackBerry Desktop Manager to erase all data and applications from the BlackBerry device. Refer to KB02318 for these steps. Once Application Loader has completed, perform a syncronization or advanced restore to restore the data to the BlackBerry device. To do this, double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
May 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
My blackberry messenger stopped working
install blackberry desktop manager
Backup the data of your Blackberry device ....
Update or reinstall the application or software with the help of blackberry desktop manager.....
Mar 11, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
21 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
