Question about Saniflo & Saniplus& Macerator Pump
Hi how can i stop the saniflo system from smelling all the time a engineer fixed it but it just smells awfull all the time is there anything that can be used to stop the smell thanks
    Problem Solver:
  • 10 Answers
The problem with the smell is that the macerator air switch manufactured by Lafoo has a diaphragm in it that tends to sag with time. The switch is mounted vertically instead of horizontally on the circuit board, which is the preferred method of operation. Huge mistake by Saniflo. This prevents the macerator from switching on properly and the unit tends to fill up to high causing the smell. The Lafoo air switch is 5.5mbar and actually has a built in adjustment dial that can be seen when one removes it from the circuit board. The solution (besides putting in a 3.5mbar Lafoo switch) is to unsolder the original switch, solder two 2" pigtails onto the switch and soldier the pigtails back onto the board. This will give you enough room to have the switch hang horizontally and allow gravity to help assist in triggering the diaphragm in the switch. Also, you will also now have the benefit of being able to adjust the sensitivity of the switch if need be depending on the atmospheric pressure where you live. The pressure side (air tube) should be on the top and not the bottom. After you make this modification, your Saniflow will work better than new and the smells will immediately dissapear. The switch will now trigger every time your flush the toilet or when the water level in the unit reaches the proper height. An enzyme type cleaner (used in RV's) will help descale any sludge in the unit but the main issue is with the air switch and how it is mounted. If you need pics of how the unit should look after it is modified, e-mail me at mrizzo@liquecolor.com My wife now has her own bathroom back!
Posted on Aug 22, 2011
Use Saniflo Descaler
Posted on Sep 22, 2010
Need to know how to fix a sometimes gas smell inside vehicle
may be a leaking tank, have it removed and pressure tested by a tank specialist.
If the smell is coming from the engine bay it might be because of fuel evaporation, do you live in a hot climate?
Jul 18, 2015 | 2001 Kia Sportage
I have a 99 chevy lumina 3.1 engine it starts up great but it smell of fumes from exhaust pipes after a while it cuts off
The problem you describe is almost certainly a bad/stopped-up catalytic converter. Not fuel line, not trunk seals, not head gasket or anything else. The fuel line answer is just wrong. If your catalytic converter is bad or stopped up, you will also almost certainly need to replace the Oxygen sensor as well.
You didn't say it smells like rotten eggs or sulfur, but that is the most commonly-stated description...it isn't accurate; a bad converter smells like a bad converter. Most people find the odor similar to rotten eggs or sulfur. A clogged exhaust system will shut an engine off after a short time due to backpressure and excessive temperature buildup.
Your check engine light should also be on. Read any diagnostic codes the PCM has set. I'm fairly sure your problem is the catalytic converter...
Steve Johnson,
Wrenching GM Cars/Trucks For 40 Years
Apr 02, 2015 | 1999 Chevrolet Lumina
I have in Intertherm gas furnace. The system runs, hot air comes out of the vents, but it smells like burnt plastic, and the red light on the circuit board is lit up...
There is a short circuit developing in an electrical circuit in the furnace. Do not turn it back on and call a service technician to examine it.
Jan 10, 2015 | Intertherm Heating & Cooling
Gas or exhaust smell through vents
This is normally a problem with the air and fuel mixture as your fuel injector may be sending too much gas through the engine and not all is burning. This can easily be fixed by having your engine properly tuned.
Mar 20, 2017 | Buick Century Cars & Trucks
Smell of Engine compartment gases (oil/antifreeze) inside the car
Check the exhaust system (even if you cant hear an exhaust leak)
Mar 29, 2017 | 1999 Lincoln Town Car
Hi every now and again we are getting a sewer smell from our bathroom we have only recently moved in the house so not sure what to do, but it doesn't seem to happen all the time and everything flushes okay...
The smell may be coming from the sink trap if there is a problem with the vent pipe (that's in the wall from the sewer line to the roof). Do you ever hear gurgling in the sink drain when you flush? When you have the smell again, stick your head in the sink and see if that's where it's coming from. If you have a floor drain, the smell may be coming from there. In either case, a bit of water added to the drain will fill the trap and stop the smell. Please vote if you found this helpful. Good luck, Al K
Feb 16, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sewer gas smell
blocked drain outside you will need to get somone in to flush it out and the problem will be solved
Dec 31, 2009 | Saniflo Sanibest Grinder Pump Only 013
Describe your Saniflo &
your p-trap is dry . the guy who did it probably didn't vent it properly, and it's being syphined. call him back to fix it.
Sep 15, 2009 | Saniflo & Saniplus& Macerator Pump
White smoke coming from AC and under hoods smells of burning oil
U HAVE A HEATER CORE LEAK, DOES THE SMOKE SMELL SICKY SWEET? AS FAR AS THE CEL GOES HAVE THE SYSTEM TESTED FOR FREE BY ANY KRAGEN AUTO OR AUTOZONE, JUST ASK FOR A OBD 2 TROUBLE CODE TEST, THEN POST THE CODE BACK HERE FOR US TO LOOK AT AND TRY AND DEVELOPE A FIX STRATEGY.
Feb 06, 2009 | 2000 Volkswagen Passat 4Motion
Saniflo & Saniplus& Macerator Pump  Logo
2,621 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
