Question about Samsung Microwave Ovens
Model MW1080sta Problem: Turntable won't turn at all. Trying to change synchronus motor. What voltage should it show when I plug in power? Wanted to test before replacing it.
    Problem Solver:
  • 17 Answers
Most ovens that I have repaired the turntable runs from 115 volt ac. Most ovens have a schmatic on the inside, look at it and follow the motor leads back to the sorce of power and check any switches or interlocks that it may go through.
good luck
Posted on May 17, 2008
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Aug 02, 2012 | GE Microwave Ovens
Microwave mod# MMV4203DQ00 - turn table does not turn
Sounds like the motor is faulty.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | Maytag Microwave Ovens
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
The glass plate inside will not rotate
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
My microwave oven turntable will not rotate. How should I solve the problem? Also if I just leave it and carry on using it does it matter? Model MICROMAT 21T-W
It is rather important having a turntable that revolves. Just as a matter of interest, place a refridgerated jelly in the microwave and watch as heat is only applied at one point!
Hope this helps.
Jan 01, 2011 | Microwave Ovens
The turntabel does not turn.
Sounds like the motor has failed.
Hope this helps.
Dec 31, 2010 | Sharp R-1870 Convection/Microwave Oven
Turntable does not turn - Whirlpool model mt910SFQ-0 - Accuwave 1000. The turntable turns erratically and only occasionally. It is accompanied by a clicking noise when it does not turn. Sounds like...
Hope this helps.
Dec 28, 2010 | Whirlpool MT9102SFB/Q Microwave Oven
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
Tray rotation motor does not work
Hope this helps.
Dec 19, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
