Looking for div x codes for pasific dvd1002 - Computers & Internet
    Scholar:
  • 55 Answers
Open www.filehippo.com
on the right hand side, you will see K-Lite Codec pack, download and install that, it will install all the video/audio codecs.
Posted on Sep 16, 2010
Unlock code
Did the default code work?I dont think its that easy.I know a site http://mobileunlockingcode.com which gives such service that is "to unlock cell phones".Actually my friend uses this site and Its great he told me.Try it out..
Dec 31, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
Tip
How to Generate Your Phone Security code..Only for Nokia bb5
This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.
3.Extract [ANT] Simple ] and run Simple.exe located in the folder
4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below
7. Nowclick on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window. Thanks For visiting Fixya
/uploads/howto/2_21_2012_7_06_24_am.jpg
/uploads/howto/2_21_2012_7_07_38_am.jpg
on Aug 18, 2011 | Cell Phones
Reset code
Hmm, actually there isn't any Master Code if you have cannged it and now have forgot your Code, then there is a 100% working solution, BUT you should have the DATA Cable (USB) of you phone which comes with the phone.
Just follow the procedure given here;
http://www.fixya.com/support/r2831734-phone_lock_code_lost_no_problem_get
And if you are asking for the default Master Code it is 12345 by default, if you haven't changed it yet.
Regards, WAQAR.
Nov 17, 2009 | Cell Phones
Abid Malik
A.A Abid.
Nokia Security codes are a bit difficult to break, the only hope is to get it back, but this can only be done(without any flashing) IF your phone can be turned on and used as normal. I mean you forgot your Code but it isn't active then you can get it back, but if your phone is asking the code at startup then :-(
So sad but true there is not such straight solution.
Regards, WAQAR.
Nov 16, 2009 | Cell Phones
Tip
Driver updates
Sometimes after a fresh install of a new operating system, the system won't recognize a certain device. If this happens then you need to update drivers in device manager.
click start,right click computer,click on manage,click on device manager,look for yellow ? and ! symbols,right click,update driver.
(note) you have to be connected to the internet for the update to work.
Hope this helps.
on Jul 18, 2011 | Microsoft Computers & Internet
Tip
How to unlock PUK code -----> For all Mobile Phones
PUK CODE its a type of security created by the mobile manufacturers to protect the mobile SIM card from theives .
PUK CODE is provided by the Service Provider.
PUK CODE is exist in the SIM CARD container (when you buy)
If you lost your SIM card container box,you can get the PUK CODE by
contacting your SERVICE PROVIDER .
You can call the Service Provider via another mobile phone or a land
phone and ask for your SIM CARD PUK CODE.
on Jun 11, 2011 | Cell Phones
Phone problem
go to the settings menu and use the factory default settings.it will require your security code an your default security code is 12345.
or use the following codes
*#7370#
*#7780#
Oct 08, 2009 | Cell Phones
Instruction Manual
ask manualfox.com -they have it in their list!
Dec 30, 2007 | Durabrand DVD-1002 DVD Player
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
