Question about Sharp AL-1551CS Copier
Copier indicates paper jam, but there is NO paper jam.
  • 1,110 Answers
Most of the time when I see this problem in the field it is cause by a bent or broken fuser gate. The gate is behind the right side door and is shown in the picture. What happens is at the rear side there is a little tab that sticks out. You can see it in the picture at the far end. That little tab trips a photo sensor. If this bar gets bent or broken then that tab does not go in far enough to trip the sensor and the machine will show a jam all the time. Normally you can fix this by opening this "gate" with the little lever shown at the front end of the picture. Then twist the plastic by pushing the sensor tab at the far end in towards the sensor hole. What you are trying to do is get that sensor tab to go farther into the sensor hole so as to trip the sensor. Once it moves farther in just shut the right side door back and see if the jam is reset.
Good Luck and Thank You for using Fixya.
Posted on Sep 18, 2010
4 Suggested Answers
SOURCE: canon 6050 copier
clean the rollersinside for paper pick up, might be dusty thats why its slipping
Posted on Apr 27, 2008
  • 57 Answers
SOURCE: canon pc 720
Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
Posted on Jul 14, 2008
goodgold
  • 389 Answers
SOURCE: Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Posted on Sep 20, 2009
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
May 25, 2010 | Canon CLC 1120 Color Copier
Paper jam indicator
Your back side of your printer might be loose
Apr 16, 2010 | Toshiba 1370 Black and White Copier
I had a jam in the paper try bypass, removed the jam, but the indicator light continues to blink. What's going on and how do i fix it?
open and close all doors on the copier ending with the front and side one.
make sure it is indicating a jam and not asking for paper in the bypass tray
Good Luck
Jan 15, 2010 | Sharp AL 1631 Copier
Sep 04, 2009 | Office Equipment & Supplies
Our Canon ImageClass D860 copier had a paper jam. We cleared the jam and did everything we were supposed to do and it still says Paper jam on the screen. We've turned it off, unplugged it and still it says...
There mite be some paper dust on the sensor where the copier indicate the paper jam is. some can air mite solve the problem. Be careful to direct can air towards the outside of the copier don't want to blow the paper dust to a different sensor
Jul 12, 2009 | Ricoh Aficio 2015 Copier
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
