Question about Coleman Electric Cooler 40 Beverage Cooler
Cooler fan runs but does not cool anymoreanymore
  • Coleman Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 17, 2010
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
My daughter's laptop Acer Aspire 5315-2713 has been experiencing sudden shutdown. I cleaned out vents and replaced cooling fan. Problem persist! I did notice cooling fan never runs. Help! What else can I...
buy your daughters laptop a laptop cooler with built in USB fans i had similiar problems with my wifes hewlett packard compaq cq bought a laptop cooler fixed the problem
(if you replaced the cooling fan why does'nt it run)
hope this helps
Oct 28, 2010 | Acer Aspire 5315 Notebook
Wine cooler not cooling below 65 lights works but not fan any ideas
Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
Feb 11, 2010 | Refrigerators
I broke my cooler :(
You can solder the two open ends of the wires/base together. Generally, it doesn't hurt at all to have the yellow wire not connected. As long as the fan is still running, you will be fine. The yellow wire gives information about the fan RPM. You just won't be alerted if the fan stops working.
Jan 25, 2010 | Foxconn CPU Cooler Fan CPU Fan
Water Cooler Not cool
hi,
Please check the control.
May 06, 2009 | Heating & Cooling
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Coleman Electric Cooler 40 Beverage Cooler Logo
547 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
