Question about IBM Office Equipment & Supplies
Correction ribbon on the ibm with ball type will not work
  • IBM Master
  • 3,594 Answers
Many possibilities. Is the T/W making all the motions of correcting and just lifting off poorly or doing nothing?
Posted on Sep 23, 2010
The ribbon won't advance
It sure sounds like something is interfering with the correction tape. Look for debris in that area.
DickyO
Oct 02, 2014 | IBM Wheelwriter 30 Typewriter
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
What would cause the ribbon guide to not lift to ball strike position?
Check ribbon adjustment there is an adjustment lever that adjusts the ribbon up and down.Also check that the ribbon is still good not wore out,out of ink.
Jun 27, 2014 | IBM Correcting Selectric III Electric...
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
When we type the keys hit above the ribbon.
Sounds like the ribbon isn't lifting try some WD40 on the ribbon motor bearings.
DickyO
Oct 15, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
Correction ribbon balls up after a short time.
Be sure that you have a dry L/O tape Gen. Ribb. # t355 or equivwlent if you are using a tacky ribbon it will give you fits.
DickyO
Jan 19, 2009 | Smith Corona Office Equipment & Supplies
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
24 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
