Question about Maxtor Hard Drive
I pluged my power plug in upside down slight flash and burn smell. can i get another pcb for the drive?
    President:
  • 2,600 Answers
I have found these available on Ebay for around 23 bucks. Just pull the number off the front of the drive and do a search.
Posted on Sep 16, 2010
Upright Vax vacuum has no suction or hadly none from the base. Belt, motor, hose all working fine
yes turn it upside down and look real close at the area where dirt goes .they do plug up when too much big stuff gets in there .
Jun 15, 2015 | Vax Vacuums
Brake light, battery light, service engine soon light on. white smoke from under the hood. area near belts loud and I smelled burning rubber. put car in park the engine shut off. What's the problem?
If your battery light came on, and you smelled burning rubber, it could be that your belt that drives the alternator, which charges your battery is broken or flipped upside down. Do not drive with the battery light on or else you will stop dead when the battery does not have enough charge in it to keep the car running. If you decide to drive and not follow my advice, then be sure all extra electrical power is off eg. radio, fan, DVD, lights etc.
Mar 29, 2015 | Cars & Trucks
Code p0301 - cylinder 1 misfire
need to do compression test first then if ok swop coils around see if fault transfers to another cylinder then its information at sensors and ecu eg volts amps earths etc
Jun 06, 2012 | 2005 Saab 9-2X
My fantom hard drive was working perfect until i unhooked it to move the computor to another area of the house. now when i pluged it up nothing happened. i may have plugged the usb upside down but not...
First of all you cannot plug the USB upside down. it always will go only in one direction. as for the **** try right click my computer/manage and see if the disk is been recognised? if not you have a driver issue or a disk issue.
Jun 09, 2009 | Fantom Drives 120 GB Hard Drive
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Wd 52725 52" mitsubishi
Good Day;
Bad news this TV has multi problems, check these:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WD-52725 52". Rear Projection...
TV will not power on. Slight electrical smell
Find out what is burning and replace it. Or call for service if that is beyond your ability.
Jan 13, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Notebook smells like burning plastic.
If the new Targus charger is really rated correctly for your laptop, your battery isn?t charging and you smell the burning plastic coming from the laptop when you plug it in that is a fairly dangerous situation and you shouldn?t plug it back in anymore. The power from the charger runs through a PCB board which distributes power to other components in your laptop. I suspect one of the components (probably a capacitor) had a catastrophic failure and is the cause of the smell and the lack of battery charging. Once again assuming that the Targus is the correct one for your laptop current you probably have a laptop damaged beyond home or economical repair.
Dec 02, 2006 | Compaq Presario 700 470024-192 Notebook
Maxtor Hard Drive Logo
66 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
