SOURCE: Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
SOURCE: I have a maytag legacy series, toploading washer.
most likely your problem is in the pump either the pump itself is bad or there is something jammed in it, remove and inspect pump replace with new one if necessary.
