Question about Maxtor Hard Drive
DVD-Rom drive doesn't work.
My disk drive tray is not opening by eject button. Took out the disk using paper clip. Tray closes by eject button. Replacement disc can't be played. This situation arised when trying to keep a record copy of a video film. Checking by 'My computer'>drive properties>it says "this drive is working properly". Checking with Nero cd-dvd speed- disc is turning & giving many results. While checking 'disc quality', it gives 'error initializing test'. With 'Bench mark' check, gives 'error! unrecovered read error(031100). 'Nero disc info.' gives 'no disk inserted or drive not ready'. My compu'r has hardware- dvd-rw drives of 'Maxtor 6Y160m0' & dvd/cd-r drive of 'Philips dvd+rw dvd8631'. Any help will be very much appreciated. I've Dell-dimension 5000, P4 processor 530, winXP-SP2 home- 3yrs old. Thanks
  • Anonymous Jun 03, 2008
    I just purchased The Maxtor 4 mini external drive. All my Dell Inspiron 2650 will do is put up a Found New Hardware MTP Device box in the lower right hand corner of the screen by the other icons. The mini 4 is not listed in Start all programs and hitting the Found New Harware box does nothing. How can I grt this Maxtor mini 4 to be recognized, as it was one time, again?
    I have just bought a Maxtor 4 mini external hd 160. I plug it into two USB ports and connect to the Maxtor mini, and all that happens is that I get a New Hardware Found MTP device box, by the other icons in the lower right hand corner of the screen. Nothing happens after that. I clicked on the box and still nothing happens. How can I install this Maxtor mini 4 external HD on my Dell 2650?
Go to "My Computer" and right-click the icon representing the drive, then select "Eject." If that works, you know your drive is OK.
Posted on Aug 29, 2008
    Champion:
  • 208 Answers
Right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
Posted on Aug 01, 2008
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Dvd stuck in computer
hi,
it is a mechanical failure.. time being use this trick. in front side of the ROM you will find the one small hole,take needle like substance around 3 to 4 inch long and put in that hole and press inside, ROM will eject....
Hope this has helped you... Thanks
Aug 21, 2010 | Dell DVD-rom DVD Drive
Disc jam
Hello there,
To manually remove any disk from your ROM tray, simply use a paper clip or any straight wire that can reach up to at least 2 inches long.
1) straighten paper clip.
2) look for the manual eject hole which is usually located near the eject button.
3) insert the pin/clip and push firmly to eject the tray.
Hope this helps.
Apr 14, 2010 | Toshiba Satellite Pro L300 Notebook
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
The door/tray will not open.
Press the open button, and quickly lift the unit 1 inch and drop it. This overcomes the strength of the magnet and allows the door to open.
Jan 20, 2008 | RCA DRC8300N DVD Recorder/VCR
Maxtor Hard Drive Logo
251 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
